    Not quite right
    3 Posts 2 Posters 322 Views 2 Watching
    • M
      matsuo_lano
      Greetings fellow Sketchers!
      I've been working on a project, in which I use 'Draw offset contours on Surface' and 'Joint Push Pull'. The overall result looks pretty nice, except for one little flaw. To illustrate the problem I've attached a screenshot and listed the settings I used below:
      With the Contours on Surface:
      'Outer contours' selected only
      With Joint Push Pull:
      Erase original faces
      Borders on outer faces only
      Influence to non-selected neighbors: yes
      Angle of influence: 0
      If you need more info, please specify!
      You try to rearrange me 'till I'm sane
      • M
        mac1
        Petey
        Form the look of your pic it appears there maybe surface and edge issues. Can you post your model to the 3d warehouse
        • M
          matsuo_lano
          @mac1 said:
          Petey
          First of all, sorry for the late reply!
          Fortunately the problem has been resolved πŸ˜„ I turned on hidden objects and simply traced the offset!
