    How make the seemless upholstery wall?
    10 Posts 5 Posters 895 Views 5 Watching
    • K
      kingtutan
      Like this
      http://i427.photobucket.com/albums/pp354/P_Surachai/stock-photo-sepia-picture-of-genuine-leather-upholstery-18047695.jpg
      • GaieusG
        There is a tutorial somewhere on these forums but I cannot find it. Hopefully someone will soon chime in and enlighten us with the location.
        • K
          kingtutan
          thank you,Ihope so .
          • numbthumbN
            numbthumb
            http://forums.sketchucation.com/viewtopic.php?f=335&t=34736
            Comfortably numb...
            • GaieusG
              Thanks NT. I remembered that it was Eric but was searching in the tutorial forums.
              I'll ask him if we could move it there (maybe leaving a link in the organic forums)
              • numbthumbN
                numbthumb
                You´re welcome. Please do so, it is a very useful tutorial indeed.
                Comfortably numb...
                • K
                  kingtutan
                  I'll try to do,thnks you both.
                  • TIGT
                    You can of course make it a physical object, after some not inconsiderable modeling and effort you'll end up with thousands of bits of geometry or at least several components for the central repeated parts and the various edge pieces... BUT have you considered using a suitable textured material applied onto a flat face? This will usually be far more efficient and it can often look as effective in many situations... Obviously 3d objects like sofas need the 3d modeling, but you said an upholstered 'wall'... which will be 'flat' anyway ?
                    • Jean-FrancoJ
                      Jean-Franco
                      Dave Richards did something to be seen here: http://www.finewoodworking.com/item/17970/upholstering-your-furniture
                      Jean-Franco
                      • K
                        kingtutan
                        I so sorry my english not well,but thank for your advise.
                        @jean-franco said:
                        I think it work for me.thanks so much.
