    Sketchup kind of 'stuck' after scripts
    13 Posts 4 Posters 815 Views 4 Watching
    • G
      ghandi
      Hey Forum,
      I am experiencing issues after invoking scripts.
      Sketchup seems kind of 'stuck' after scripts are executed.
      That means I can't click or select any Object.
      I need to press spacebar once, then everything seems fine again.
      What am I missing? Any Ideas?
      Thank you.
      • voljankoV
        voljanko
        It all depends of the letters in your scripts πŸ˜‰
        SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
        • G
          ghandi
          Do you have any hints?
          I tried
          model.active_view.refresh
          or
          selection.clear
          but none helped.
          If you want me to post all that code I'll do.
          Mainly that are modified versions of Fillet.rb, Pipe_along_Path.rb.
          • voljankoV
            voljanko
            First step would be to check if the original versions work ok for you.If yes,than find the differences.Than add every difference to the original(working) code.Then you will know what line makes your code not working.
            • G
              ghandi
              will do.
              • TIGT
                I suspect that you have made a 'tool' that doesn't exit but sits there waiting for more input... without giving us some clues with your code we can't really help much more 😞
                • G
                  ghandi
                  So I figured the problem arises from the originalfillet.rb (attached)
                  For my modified version I mainly removed following lines
                  89-91
                  101-103
                  110-126
                  166-167
                  so these lines can't be responsible for the problem.
                  The remaining code looks normal to me.
                  I tried to locate the problem by putting returns here and there but no
                  original from http://video.suplugins.com/download/fillet.rb
                  • voljankoV
                    voljanko
                    Nothing is wrong.You are just "in the tool".
                    When the tool is selected,you can do just what the tool let you do.So it can be like stuck.
                    You just have to select other tools to exit this tool.
                    • G
                      ghandi
                      That's it.
                      So I just activate the "Select-Tool" with
                      Sketchup.active_model.select_tool(nil)
                      Is that what I want?
                      Or is there an other way to close the Tool?
                      Thank you
                      • voljankoV
                        voljanko
                        If you want to "close" a tool,you have to select another tool.
                        If you want to do it in code,try
                         Sketchup.send_action "selectSelectionTool;"
                        ,or other tools you want.
                        • G
                          ghandi
                          Solved. Thank you very much.
                          • thomthomT
                            Does that work on OSX?
                            A safer method is Sketchup.active_model.select_tool( nil )
                            • TIGT
                              Sketchup.send_action("selectSelectionTool:") should work cross-platform - it's only the numerical codes that are PC specific like Sketchup.send_action(10501) which is PC only whereas the equivalent Sketchup.send_action("viewTop:") works on PC & MAC...
