    [Plugin] QuadFaceTools
    673 Posts 116 Posters 518.4k Views 116 Watching
    • ithilI Offline
      ithil
      Yes of course. Here are all these files
      obj.zip
        [attachment=0:16xvwwwa]<!-- ia0 -->obj.zip<!-- ia0 -->[/attachment:16xvwwwa]
        Something in your export process hard code the full path to the textures - instead of relatives.
        # 3ds Max Wavefront OBJ Exporter v0.97b - (c)2007 guruware
        # File Created; 19.01.2016 12;57;08
        newmtl CHECKER_V1
        	Ns 30.0000
        	Ni 1.5000
        	d 1.0000
        	Tr 0.0000
        	Tf 1.0000 1.0000 1.0000
        	illum 2
        	Ka 0.0000 0.0000 0.0000
        	Kd 0.3882 0.3922 0.3882
        	Ks 0.3300 0.3300 0.3300
        	Ke 0.0000 0.0000 0.0000
        However on your own machine you'd think it'd stil work...
        • ely862meE Offline
          ely862me
          Can I select the place where loops are inserted? They usually are inserted at the half of the line you choose, is there any way that would change ?
          Elisei (sketchupper)
          Come and See EliseiDesign
            cuttingedge
            HI Thomas, Just to drop a note that i really did appreciate QFT now that SubD is out and prove to be one of the most useful plugin.
            Just wondering if we have a "relax tool" in the QFT suite or in any plugin you authored. I hope I know what im saying by relax which means to kind of smooth out the geometry without subdividing it but not destroying the quadface integrity of the model.
            • BoxB Offline
              Probably the easiest way is to add more loops and delete the ones you don't need.
              Select the ring, then connect edges to create more loops then use the remove loop button.
                In this particular case maybe this is more speedy! πŸ˜„
                3 times Edge Tools / Divide faces by Thomthom
                and copy the last edge
                Like this there no internal face created
                • BoxB Offline
                  Try that with a more complex shape pilou.
                  QFT doesn't create internal faces either.
                    Not with the Insert Loop function, no. I have been looking into a new tool for this - but its not complete.
                    There is an experimental prototype in the latest versions, but it got some flaws. Need to rethink it.
                      cuttingedge
                      @thomthom said:
                      You mean something like this?
                      http://sketchucation.com/forums/download/file.php?id=131939
                      http://sketchucation.com/forums/download/file.php?id=131940
                      http://sketchucation.com/forums/download/file.php?id=131941
                      Sorry, do image display on my browser.
                          I'm not sure if I fully understood that sentence. But I assumed you meant that you couldn't see the images? In any case, I went back and re-uploaded the images.
                            cuttingedge
                            Whoaa..Where did this come from? Where do I find this?
                            Hope this relax tool be part of your quadface suite , even the insert loop similar to that of 3ds max 'graphite tool' where you can pick the exact point where you want it placed.
                            • ely862meE Offline
                              ely862me
                              Hi Box and Pilou,
                              Thanks for the tips!
                              I tried your method,Box but it gives me some errors here and there when removing the extra loops.
                              I think the adding loops is better though, as you first insert one at the middle then you insert one in the half you want, and so on. At the end there are fewer loops to remove and fewer errors. It is better to remove the extra loop immediately you created the new one.
                              Yes, Thomas, loop offset would be a great addition. Unless you can create a loop mover that would move the loop at a specified point after it was inserted-something like moving a section cut plane back and forth.
                              The Line tool is still unpolishead leaving behind here and there both diagonals.
                                @Box
                                It's for that i have said "In this particular case"! πŸ˜‰
                                Sure but "Edge tool" yes, it's for that I had not made the last edge with it! πŸ˜‰
                                  At the moment it's part of Vertex Tools 2.0 that I'm working on.
                                  • H Offline
                                    hsrhdrehre5654654
                                    Hi, great tool, trying to figure it out since i started organic modelling just yesterday.
                                    I cant find the option "Convert Connected Mesh to QuadFaces". I know there are 3 connect options, but none of em are the one im looking for. At least that option is commented in the documentation but in the plugin itself, i cant find it.
                                    Im trying to convert a simple regular model to a quad faced model (to ensure all the faces are at least quad based), and that would be the option to use. Is it not implemented yet??
                                      That's probably the old name of "Convert Triangulated Mesh to Quads" - looks like docs are out of date. New version is coming though.
                                      Btw, if you plan on using Artisan for subdivision then converting to QFT quads won't have much use - as it will treat QFT quads as two triangles instead.
                                      • H Offline
                                        hsrhdrehre5654654
                                        Oh, i see. I didnt know Artisan manages faces as triangles and not quads.. i was trying to make all my faces as quads, because as i understand, they create better geometry and honestly dealing with triangles is an odyssey. Triangles are giving me a lot of trouble to create the correct geometry. Thats the reason i wanted to just pick a plain model and make quadfaces without the need to do it manually (it could take ages). Or probably since im new to Artisan and organic modelling i dont even know what im doing lol. Maybe is there a basic tutorial about organic modelling in sketchup πŸ˜‰ ?
                                        Maybe the whole approach im taking is wrong. And i dont even know where to start with dealing with organic modelling. The tutorials i found are based on relative basic models and all of em assume that the user already created the original mesh (control mesh i think its called). Well, i need to first get there...
                                        What im doing is, i just create a cube and is tart adding quadfaces and extruding until i get the geometry i want (more or less). Then , in the curved surfaces i want to achieve i just join the quads creating the smooth geometry i want to get. I mean, is that the correct way or i am doing it wrong?
                                        In the past , in some of my projects, for example, if i am modelling a spaceship what i do is to create the side profile, and the top profile. Then i create the geometry from that, i extrude and i mix the two parts to get the final form. Sometimes instead of that i just use the join faces plugin (cant remember the autor) to join the side and the top (slighty inclined to get the aspect of a hull wing, for example). And other methods depending of the type of the model.
                                        In cases where i need to almost copy a image of a model, thats the best way i found. But i cant do it dealing with organic modelling because the faces it generates are too different in size/number of faces and in the end is a chaos.
                                        So, i imagined that the best way using quadfaces + artisan is starting with just a cube and start making faces and extruding?? the problem with that is, to achieve the form from the original image is really hard. Talking about more complex models.
                                        So any ideas on how to even start making an organic modelling? i am doing it right?
                                        If thats the prcedure, how can i divide the surface of the cube, lets say into visible quadfaces??
                                        Thanks in advance and sorry for the text wall. Amazing plugin Artisan and a great one Quadfaces, if i figure out a method to apply textures without losing distorsion / size i will definetly buy it!!. But at this rate im afraid i will not have time to even test the plugin before it expires lol!!
                                          If you have a model with native planar quads in SketchUp I believe Artisan will treat them as such - splitting each quad into four new quads.
                                          However, if you need to produce non-planar quads then the extensions would need to support the type that QuadFace Tools defines (https://bitbucket.org/thomthom/quadface-tools/wiki/Overview#!quadface-definition). Currently Artisan doesn't do this - and will therefore treat the two triangles separately. I'm not 100% sure, but I do think that Artisan uses a hybrid of Catmull-Clack subdivision (for quads) and Hull (for triangles). That allows it do create smoother subdivisions when you are not dealing with only triangles.
                                          Marcello created a nice tutorial recently that will take things step by step:
                                          https://www.youtube.com/watch?list=PLaL30WxyeD1XNay4pinirG5wU4L5-O7_4%26amp;v=Yb64ZH5p8Do
                                          While it's aimed at SUbD the same concepts can be applied to Artisan - only key different is the non-planar quad support.
                                          Since both extensions are using common subdivision algorithms other applications also use you can apply the same concept from other applications (tutorials). (Though the video series above do show concrete examples in SU which is nice.)
                                          Also, there is a thread here that contain a large set of examples that show key concepts with modelling with low-poly and subdividing. Even got a good number of examples SKP models attached one can inspect: http://sketchucation.com/forums/viewtopic.php?f=397%26amp;t=63826
                                          Again it's SUbD centric, but as I mentioned you can apply the same concept to most subdivision extensions.
                                          Topology for subdivision can be a challenge. I've been starting to collect links to resources on this topic: http://evilsoftwareempire.com/subd/quads
                                          These links are software agnostic - they describe topology on the general level. I find this Tumbler page to be really nice as it demonstrate common pattern one can apply when you start to need more complex surfaces: http://topology-guides.tumblr.com/
                                          Both SUbD and Artisan allows you to subdivide and keep materials. You also got other extensions you can try post-subdivision like Fredo's ThruPaint (http://sketchucation.com/forums/viewtopic.php?t=44552) - or Dale's SketchUV (http://sketchucation.com/forums/viewtopic.php?t=44501) which allows you to export to external third party UV mapping software and back into SketchUp.
                                          I'd highly encourage to post pictures of what you want to model, describe certain pieces that poses a challenge. I'm sure there won't be missing suggestions and solutions in response.
                                          • H Offline
                                            hsrhdrehre5654654
                                            Thanks Thom, but i think i didnt explain very well (sometimes happens, for not being a english speaker.. :s). Again, i already saw all those tutorials, and they are great but how can i make my cube, to be divided by subdivisions before even i use the subd or artisan plugin??? that is what i want to know in first place. I see models in the tutorials, but again they are already divided by subdivisions in the control mesh. How do i get there?? there is not one single tutorial that explains that. Are those subdivisions created manually??
                                            About materials. I know artisan and subd can keep materials, but the results are really bad. Distorted textures, streched and so on. So, in the end is completely useless. Its even better to texture AFTER the subdivision, not before. But then again, how???? i mean in simple models and models with simple geometry this is not a problem, but in things like complex space ships, organic modelling like faces and things like that??
                                            Also mapping the uvs in, for example killroad doesnt help me because the problem i have is not that. The problem i have with textures is, the whole texture must be placed along the whole model, but i dont want it to be distored in the sides, for example. And every single texturing plugin do the mapping based on a plane, so, i always have distorted textures in some places. I just want the same texture in the top of the model and in the side, but continous. Without seamless and without distorted textures. I start thinking thats not possible with sketch up lol. Before you say it, yes i tried the thrupaing from Fredo, and its a great tool, but again, IT ONLY WORKS WITH QUADFACES... so, it is not really useful to me. Already tried, and i cant get what im looking for.
                                            So, on a side note, im assuming texturing has nothing to do with dealing with quadfaces or triangles? its always the same result?.
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 33
                                            • 34
                                            • 22 / 34
