    [Plugin] QuadFaceTools
    680 Posts 116 Posters 647.9k Views 116 Watching
      @cuttingedge said:
      Sorry, do image display on my browser.
      I'm not sure if I fully understood that sentence. But I assumed you meant that you couldn't see the images? In any case, I went back and re-uploaded the images.
        cuttingedge
        @thomthom said:
        You mean something like this?
        Whoaa..Where did this come from? Where do I find this?
        Hope this relax tool be part of your quadface suite , even the insert loop similar to that of 3ds max 'graphite tool' where you can pick the exact point where you want it placed.
        • ely862meE Offline
          ely862me
          Hi Box and Pilou,
          Thanks for the tips!
          I tried your method,Box but it gives me some errors here and there when removing the extra loops.
          I think the adding loops is better though, as you first insert one at the middle then you insert one in the half you want, and so on. At the end there are fewer loops to remove and fewer errors. It is better to remove the extra loop immediately you created the new one.
          Yes, Thomas, loop offset would be a great addition. Unless you can create a loop mover that would move the loop at a specified point after it was inserted-something like moving a section cut plane back and forth.
          The Line tool is still unpolishead leaving behind here and there both diagonals.
          Elisei (sketchupper)
          Come and See EliseiDesign
            @Box
            Try that with a more complex shape pilou.
            It's for that i have said "In this particular case"! πŸ˜‰
            QFT doesn't create internal faces either.
            Sure but "Edge tool" yes, it's for that I had not made the last edge with it! πŸ˜‰
              At the moment it's part of Vertex Tools 2.0 that I'm working on.
              • H Offline
                hsrhdrehre5654654
                Hi, great tool, trying to figure it out since i started organic modelling just yesterday.
                I cant find the option "Convert Connected Mesh to QuadFaces". I know there are 3 connect options, but none of em are the one im looking for. At least that option is commented in the documentation but in the plugin itself, i cant find it.
                Im trying to convert a simple regular model to a quad faced model (to ensure all the faces are at least quad based), and that would be the option to use. Is it not implemented yet??
                  That's probably the old name of "Convert Triangulated Mesh to Quads" - looks like docs are out of date. New version is coming though.
                  Btw, if you plan on using Artisan for subdivision then converting to QFT quads won't have much use - as it will treat QFT quads as two triangles instead.
                  • H Offline
                    hsrhdrehre5654654
                    Oh, i see. I didnt know Artisan manages faces as triangles and not quads.. i was trying to make all my faces as quads, because as i understand, they create better geometry and honestly dealing with triangles is an odyssey. Triangles are giving me a lot of trouble to create the correct geometry. Thats the reason i wanted to just pick a plain model and make quadfaces without the need to do it manually (it could take ages). Or probably since im new to Artisan and organic modelling i dont even know what im doing lol. Maybe is there a basic tutorial about organic modelling in sketchup πŸ˜‰ ?
                    Maybe the whole approach im taking is wrong. And i dont even know where to start with dealing with organic modelling. The tutorials i found are based on relative basic models and all of em assume that the user already created the original mesh (control mesh i think its called). Well, i need to first get there...
                    What im doing is, i just create a cube and is tart adding quadfaces and extruding until i get the geometry i want (more or less). Then , in the curved surfaces i want to achieve i just join the quads creating the smooth geometry i want to get. I mean, is that the correct way or i am doing it wrong?
                    In the past , in some of my projects, for example, if i am modelling a spaceship what i do is to create the side profile, and the top profile. Then i create the geometry from that, i extrude and i mix the two parts to get the final form. Sometimes instead of that i just use the join faces plugin (cant remember the autor) to join the side and the top (slighty inclined to get the aspect of a hull wing, for example). And other methods depending of the type of the model.
                    In cases where i need to almost copy a image of a model, thats the best way i found. But i cant do it dealing with organic modelling because the faces it generates are too different in size/number of faces and in the end is a chaos.
                    So, i imagined that the best way using quadfaces + artisan is starting with just a cube and start making faces and extruding?? the problem with that is, to achieve the form from the original image is really hard. Talking about more complex models.
                    So any ideas on how to even start making an organic modelling? i am doing it right?
                    If thats the prcedure, how can i divide the surface of the cube, lets say into visible quadfaces??
                    Thanks in advance and sorry for the text wall. Amazing plugin Artisan and a great one Quadfaces, if i figure out a method to apply textures without losing distorsion / size i will definetly buy it!!. But at this rate im afraid i will not have time to even test the plugin before it expires lol!!
                      If you have a model with native planar quads in SketchUp I believe Artisan will treat them as such - splitting each quad into four new quads.
                      However, if you need to produce non-planar quads then the extensions would need to support the type that QuadFace Tools defines (https://bitbucket.org/thomthom/quadface-tools/wiki/Overview#!quadface-definition). Currently Artisan doesn't do this - and will therefore treat the two triangles separately. I'm not 100% sure, but I do think that Artisan uses a hybrid of Catmull-Clack subdivision (for quads) and Hull (for triangles). That allows it do create smoother subdivisions when you are not dealing with only triangles.
                      Marcello created a nice tutorial recently that will take things step by step:
                      https://www.youtube.com/watch?list=PLaL30WxyeD1XNay4pinirG5wU4L5-O7_4%26amp;v=Yb64ZH5p8Do
                      While it's aimed at SUbD the same concepts can be applied to Artisan - only key different is the non-planar quad support.
                      Since both extensions are using common subdivision algorithms other applications also use you can apply the same concept from other applications (tutorials). (Though the video series above do show concrete examples in SU which is nice.)
                      Also, there is a thread here that contain a large set of examples that show key concepts with modelling with low-poly and subdividing. Even got a good number of examples SKP models attached one can inspect: http://sketchucation.com/forums/viewtopic.php?f=397%26amp;t=63826
                      Again it's SUbD centric, but as I mentioned you can apply the same concept to most subdivision extensions.
                      Topology for subdivision can be a challenge. I've been starting to collect links to resources on this topic: http://evilsoftwareempire.com/subd/quads
                      These links are software agnostic - they describe topology on the general level. I find this Tumbler page to be really nice as it demonstrate common pattern one can apply when you start to need more complex surfaces: http://topology-guides.tumblr.com/
                      Both SUbD and Artisan allows you to subdivide and keep materials. You also got other extensions you can try post-subdivision like Fredo's ThruPaint (http://sketchucation.com/forums/viewtopic.php?t=44552) - or Dale's SketchUV (http://sketchucation.com/forums/viewtopic.php?t=44501) which allows you to export to external third party UV mapping software and back into SketchUp.
                      I'd highly encourage to post pictures of what you want to model, describe certain pieces that poses a challenge. I'm sure there won't be missing suggestions and solutions in response.
                      • H Offline
                        hsrhdrehre5654654
                        Thanks Thom, but i think i didnt explain very well (sometimes happens, for not being a english speaker.. :s). Again, i already saw all those tutorials, and they are great but how can i make my cube, to be divided by subdivisions before even i use the subd or artisan plugin??? that is what i want to know in first place. I see models in the tutorials, but again they are already divided by subdivisions in the control mesh. How do i get there?? there is not one single tutorial that explains that. Are those subdivisions created manually??
                        About materials. I know artisan and subd can keep materials, but the results are really bad. Distorted textures, streched and so on. So, in the end is completely useless. Its even better to texture AFTER the subdivision, not before. But then again, how???? i mean in simple models and models with simple geometry this is not a problem, but in things like complex space ships, organic modelling like faces and things like that??
                        Also mapping the uvs in, for example killroad doesnt help me because the problem i have is not that. The problem i have with textures is, the whole texture must be placed along the whole model, but i dont want it to be distored in the sides, for example. And every single texturing plugin do the mapping based on a plane, so, i always have distorted textures in some places. I just want the same texture in the top of the model and in the side, but continous. Without seamless and without distorted textures. I start thinking thats not possible with sketch up lol. Before you say it, yes i tried the thrupaing from Fredo, and its a great tool, but again, IT ONLY WORKS WITH QUADFACES... so, it is not really useful to me. Already tried, and i cant get what im looking for.
                        So, on a side note, im assuming texturing has nothing to do with dealing with quadfaces or triangles? its always the same result?.
                          In most cases yea. I either use the native tools and copy-array edges along the sides to split them up. Or I use QFT to do so. I have on my list of things to do to add some basic tools to draw basic primitives with control over how to split up the faces. Also got plans to allow SUbD to split faces without smoothing the mesh.
                          At the moment SUbD makes linear interpolation of UV mapping, which will cause stretching when you have a small face next to a large face - the UVs of the small will appear to smudge. With the upgrade to using OpenSubdiv I think I got alternative UV interpolation features that will help in this respect.
                          Here I'd like to urge you again to post a sample so we can see exactly what you are referring to. It's very easy to think we are talking about the same thing while in reality we don't - one of the challenges with text communication. So please upload a sample model or screenshot.
                          Quads are optimal for topology - the reason is that the mesh gets a direction and flow. Without it its very hard to write tool to manipulate the mesh. This include UV mapping.
                          You'll find that most articles that describe topology recommends quads over tris - and noone ever recommend ngons.
                          http://blog.digitaltutors.com/ngons-triangles-bad/
                          https://resources.squid.io/checkmate-3d-modeling-standard/checkmate-specifications-overview/checkmate-pro-checklist/tris-quads-n-gons/
                          Again I'd recommend that you post some examples - then we'd have something concrete to look at and might be able to provide specific solutions for you instead of just generic ones.
                            rv1974
                            Thomthom do you have plans to add the X-ray proxy mode?
                            I some models I say modelling issues in areas of mirroring plane. The meshes do not flow seamlessly\smoothly from one half to another. What do you think of kind of symmetry modifier? Or its better to keep it simple and do it 'by eye'? but in this case proxy mode would help a lot.
                            And thank you btw for yet another blockbuster.
                              Can you refresh my memory?
                                rv1974
                                the overlay of semi-transparent low-poly boxy proxy over end mesh:
                                https://youtu.be/5LcLPPz0fWM?t=3m17s
                                • H Offline
                                  hsrhdrehre5654654
                                  This is the model in working on, it is just a really earlier version (the tunning will come once i know that i can effectively texture it), this is going to be half of a spaceship (with a semi-organic hull). Once im done with this half, i clone it, flip it and i mix it with the other half, forming the whole hull (and probably i will need to cut it in 2 or 3 pieces as well).
                                  http://i.imgur.com/hZlkDfE.jpg
                                  The screenshot is only a level 2 subdivision with Artisan, i plan to do a level 3 in the final version (i hope my computer and sketchup can handle it).
                                  So, my question would be, how i texture this? i want to apply just 1 single texture in the whole model (since the small details can be easily textured later), spreading from top to sides. Cant use thrupaint because im using Artisan and most of my faces are triangles (its impossible to build these shapes with just quadfaces, or i dont know how, i dont see how..) and as you know thrupaint only works with quadfaces. Sketchuv also is not useful, because i keep getting distorsioned textures no matter what i try. I could create paths and define the zones where the textures are distorsioned, but then i would need to MANUALLY position and allign/resize each face. And that, well i dont think i can do it lol, not with thousands faces.
                                  The wip mixing two halfs -> of course, i will texture just 1 half before i make the whole mix. Do you think that this kind of mesh could be done with just quadfaces?
                                  http://i.imgur.com/ajre7cr.jpg
                                  Thanks in advance!.
                                    I have some other ideas I'd like to explore related to that.
                                      Given such an organic shape I think a UV unwrapping tool is best for you. Ideally you'd uv map the low-poly version - though as you say currently the subdivisions might distort some of the mapping. I'm hoping OpenSubdiv will address that - but it's still in development.
                                      Do you have some image of the low poly version?
                                      Or even a sample model of where UV mapping distorts when subdivided? (It's help a lot to have test models for this.)
                                      Btw, you can upload images directly to the forum - saves you round-tripping to image-hosting sites:
                                      • jiminy-billy-bobJ Offline
                                        jiminy-billy-bob
                                        I'd be awesome to have your custom PushPull working on the subdivided mesh (but PushPulling the low-poly quads, not the subdivided tris like it does now)
                                          Yes - however tools are very time-consuming and difficult to make work well. I'm contemplating something that would let me utilize the existing tools - to act on the base mesh but be able to display the subdivided mesh as the same time. πŸ€“
                                          • ely862meE Offline
                                            ely862me
                                            Well if it is not that difficult to have one texture applied to the whole model, then why don't you just do it !?
                                            It is hard to ask for things that you don't even understand the concept of..
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 33
                                            • 34
                                            • 22 / 34
