Free 3D Models
I have found another page with a lot of free 3D models.
http://archive3d.net/?category=1055
Charly
Wow, good find.
Next step - to find a way of converting *.gsm and *.3ds files into sketchup files!
If you've SU Pro you can just import them. Not sure if the Free version can?
Yes it can.
I'm not completely sure if there's a 'Free' .3ds importer, but there are some other 3rd-party importers for file format's like .dxf, .obj etc [and .dae and several other format importers too are available in 'Free']; so if you don't have 3ds as an import option [check the file-types in the import dialog???] you can then find an intermediary-exe that'll read in the file and export it to one of those other formats that you can import into 'Free'... This applies to other file-types too, that might not be listed in the import dialog dropdown list............
Meshlab for intermediary?
So you´re saying that it´s not possible to import .3ds files directly with the free version?
I have the Free version of SU 8 and the pro version of SU 7, I can import 3DS directly into both.
I have 'Pro' so I can import everything that's possible.
The 'Free' version does have limited importers... but after investigating further I now understand that 3ds is one of the importers that Free has [but the exporters are more limited]. So if you have Free just look at the list of available file formats under 3d import !
[If you had done this you needn't have asked at all
If 3ds isn't there use the convoluted route, but if it is there just go and do it!
Also I suggest that you read the Sketchup Help files - search '3ds import' etc... -
@numbthumb said:
Yes it can.
I have checked it out already, I was just confused with all that "intermediary" stuff
Sorry for the confusion.
The initial inquirer would have been well advised to check what he could do first - it's difficult for Pro users who have no access to the Free version to help sometimes
No problem, TIG.
@icedkasz said:
... find a way of converting *.gsm and *.3ds files into sketchup files!
Has anybody found a way of batch converting Archicad *.gsm files to *.skp files? Apart from opening them in Archicad and manually exporting them one by one?
Alternatively batch converting Archicad *gsm to *.ifc files?
Register LoginAdvertisement
