    How do i change length attributes in ruby
    3 Posts 2 Posters 770 Views 2 Watching
    • A
      agenor
      How do i change the length attributes lenx, leny, lenz to a value without using a formula.
      if i use the set_attribute('dynamic_attributes', '_lenx_formula', number)
      the component will not be scalable anymore
      • A
        agenor
        please can somebody tell me if there is a solution for this
        or does i have to make change request to the sketchup developer team?
        • TIGT
          You have double posted - in the other thread there is some useful advice please read it.
          If you use Ruby code to reset the formula to be a fixed number how can you expect it to be a formula again later on?
          You must change the attributes that the formula is using to effect a change that is not permanent! The formula cannot be changed in anyway without changing how the DC works.
          There are also other DC Ruby tools to scale objects too...
