    [Plugin] Drop Vertices
    51 Posts 17 Posters 151.4k Views 17 Watching
      Copyright 2011, TIG (c)
      Permission to use, copy, modify, and distribute this software for any
      purpose, and currently without fee, is hereby granted, provided that
      this text and the above copyright (c) notice appear in all copies.
      This software is provided "as is" and without any express or implied
      warranties, including, without limitation, the implied warranties of
      merchantability and fitness for a particular purpose.
      Menu: 'Plugins' > 'Drop Vertices...' >
      'To Nearest Object'
      'To Nearest Below'
      'To Nearest Above'
      'To Nearest+Z=?'
      'To Lowest'
      'To Highest'
      'To Middle'
      'To Average'
      'To Z=?'
      'To Z=%'
      Usage:
      Preselect the edges where you want vertices to 'adjust', choose tool...
      'To Nearest Object' means all of the edges' vertices will 'drop' on to
      the 'objects' below them, OR 'lift' to the 'objects' above them if there
      was nothing below, or to Z=0 if there is nothing above/below.
      'To Nearest Below' means all of the edges' vertices will 'drop' on to
      the next 'object' below them, or to Z=0 if there is nothing below.
      'To Nearest Above' means all of the edges' vertices will 'lift' up to
      the next 'object' above them, or to Z=0 if there is nothing above.
      'To Nearest+Z=?' means you enter the default drop Z value in a dialog
      and it then does the equivalent of 'To Nearest Object' BUT stops at
      the specified Z value [rather than Z=0] is nothing is above/below.
      'To Lowest' means all of the edges' vertices will 'drop' to match the
      Z value of the lowest selected vertex.
      'To Highest' means all of the edges' vertices will 'lift' to match the
      Z value of the highest selected vertex.
      'To Middle' means all of the edges' vertices will 'adjust' to match the
      mid Z value between the highest and lowest selected vertices.
      'To Average' means all of the edges' vertices will 'adjust' to match the
      average Z value of all of the selected vertices; this is not necessarily
      the same as 'To Middle' as a disproportionate number of low vertices
      in the selection will reduce the average but not affect the mid value.
      'To Z=?' means a dialog asks for the Z value; enter a number to use
      current-units e.g. 123 might be 123" or 123mm depending on the model's
      current units; to use something other than the current units suffix the
      number thus '123mm' to use 123mm when your units might be in 'meters':
      the vertices will all adjust to that specified Z value: default Z=0.
      'To Z=%' means that a dialog asks for the % [Percentage]; enter a
      value: the default is 100 which means 'no change': entering a smaller
      value, say 50, will adjust each selected vertex to be 50% its height
      above the lowest selected vertex [i.e. the mesh is 'deflated']; entering
      a higher value, say 150, will adjust each selected vertex to be 150%
      its height above the lowest selected vertex [i.e. the mesh is
      'inflated']; entering 0 will completely 'flatten' the mesh to the level
      of the lowest selected vertex [equivalent to using 'To Lowest'];
      entering negative values will 'flip' the mesh - so -100 will invert it,
      -50 will invert it and deflate it, and -150 will invert it and inflate
      it.
      Donations: PayPal.com to info @ revitrev.orgPayPalButton###
      Version:
      1.0 20110806 First issue.
      1.1 20110807 Nearest-Below/-Above, Middle/Average and Z=% options added.
      1.2 20110807 Nearest+Z=? option added.
      1.3 20110810 Glitch with Lowest/Highest/Middle fixed.
      2.0 20150422 Glitches with dropping curves resolved.
      Put into the Plugins folder and restart Sketchup [read the instructions!]...
        Excellent
          [flash=800,600:1cf7fpkt]http://www.youtube.com/v/vD8DBSvtLcU[/flash:1cf7fpkt]
            Thanks Rich [he's now my official my publicist! πŸ˜‰ ]
            πŸ˜„
            That's also a nifty tool you have that's showing the Tools being used 'on-screen' - what is it?
            πŸ˜‰
            Hope this is a useful tool - feedback please...
            β˜€ Incidentally... when a mesh's 'corner' drops as a 'flat-square', whilst some other seemingly identical corners drop to a nice 'point' it's because the mesh's diagonal at that corner is 'across' the corner so it is the correct result. If you don't want that you can undo the 'drop' and then set "View > Hidden Geometry > ON" and use the 'Sandbox Tool' > 'Flip Edges' to swap the problem diagonal[s] to arrive at the 'apex' of the corner[s]; then just redo the 'Drop Vertices' to get all 'pointy' corners [OR of course do the reverse to avoid any 'pointy' corners at all πŸ˜’ ]... πŸ˜„
              This deserved a little video I thought. Especially for those inclined not to read your blurb.
              Something I cobbled together called 'Onscreen Rolling Reel' but it's very buggy at the moment and being unemployed I've no time to sort the code πŸ˜’
              You actually missed the other hidden gem I used in there....SplitUp πŸ˜‰ again a nifty tool that's buggy as bejaysus πŸ˜’
                • mitcorbM Offline
                  mitcorb
                  @TIG:
                  First of all, an excellent script. I applaud your generosity.
                  Your " β˜€ Incidentally..." paragraph above refers to the end frame image in Rich's video, right hand corner of the model, am I correct?
                  @Rich: Thank you for the excellent video tutorial.
                    These 'flat' corners are simply a result of the mesh's diagonals at its corners.
                    My 'flip' tip was how to avoid it [or indeed ensure it]... and 'cut off the complainers at the pass...' πŸ˜‰ - because it's only doing what it's been told...
                    • EarthMoverE Offline
                      EarthMover
                      Very nice TIG!!!! This is a much needed plugin! πŸ‘ πŸ‘ As soon as I get some paying work again, I'll definitely drop a ten spot in your paypal account!
                      Content Creator at Skapeup
                        jorge2011
                        Thanks for this new tool, Mr. tig, is very useful.
                        Mr. Rich O'Brien.
                        Where I can download the plugin split up?
                          You can't
                            jorge2011
                            Excuse me, but I do not understand.
                            Does not exist plugins? payment is a plugin?
                              Sorry, but it's not available. Maybe in the future?
                                rv1974
                                And practically, what one could model with this ruby?
                                What's the aim?
                                • Bob JamesB Offline
                                  Bob James
                                  What's the aim?
                                  This:
                                  http://forums.sketchucation.com/viewtopic.php?f=15&t=39224
                                    Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=346754#p346754
                                    Several additional features added - please read first post...
                                      EarthMover
                                      TIG, would it be possible to add an option which is drop verts to =Z /to intersect. Meaning if you had the subdivided plane above, let's say a smaller box, then all verts would drop to the specified Z, except where they intersected with the box. Perhaps adding a "Drape Verts" choice to the submenu. It would essentially do what drape Cpoints and triangulate does, but with a predefined mesh.
                                      Thanks for your work on this again. The new features are great. πŸ‘
                                        I'll look at adding 'To Nearest + Z = ?' too... It should be too difficult...
                                          Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=346754#p346754
                                          'To Nearest+Z=?' option added for 'draping' whole mesh over objects.
                                            EarthMover
                                            Wow, that was fast! I'll give it whirl and let you know how it works.
                                            • 1 / 3
