    Problems exporting elevations to Autocad
    5 Posts 3 Posters 1.1k Views 3 Watching
    • L
      lapx
      I have noticed this before but dont know how this was ever resolved. I have problems exporting elevations set up as scenes in sketchup exported to 2d in Autocad.
      I have done this many times in the past and and worked well. Now I run into problems exporting some files. Its only exporting a few lines and in some cases not the same scence. Might styles in some way be affecting my output to 2d?
      • L
        lapx
        Have no idea why this does not work. I cannot export acad dwg without loss of lines. Can anyone debug this? However, it does work when I copy just the building into a new file. πŸ˜•
        http://www.megaupload.com/?d=3GE60VHZ
        • L
          lapx
          Anyone have any luck on exporting the elevations in autocad? I get a sectioncut line at the ground level an no other lines???? πŸ˜• Please help!
          Thanks,
          • TIGT
            The SKP needs reworking with some layers to control visibility rather than 'hiding stuff' - which I think is the issue, as it then obscures what you want to see, as 2d it's all in 'hidden line'.
            Here's a full 3d DWG export with NO hidden line info suhart2.zip
            • S
              smhbrv
              Hi everyone.
              My problem is about Export to Autocad.
              I draw my project in Sketchup and I export to Autocad with 2d.
              When I use in Sketchup, Export>2d>Autocad lots of line seems.
              Can you help me pls?
              Sketchup Export Options
              When export to autocad.
              There is my sketchup file.
