    500 Plugin Requests
    14 Posts 8 Posters 1.8k Views 8 Watching
      Jim
      I was just cleaning up the Plugins and Dev Forums, and amazingly found nearly 500 plugin requests...
      [Req] rotate with chosen angle
      [Req] Is there a Noise plugin?
      Rotate and Align Plugin request
      PLUGIN REQUEST - GFA Calculation
      [Request]Reset Interface or Turn all Plugins on/off
      [REQ] close gaps and unify lines
      {REQ} Perimeter Trace?
      [REQ] Scale Mutiple? (why not in FredoScale 😄
      [Request]Axis Rotate
      {REQ} Collada Mass Export by layer
      [Request] Name, Definition Name of Components
      [REQ] Selection by Surface ?
      Request
      Intersection Plugin Request
      [REQ] copy along path keeping perpendicular
      [url=http://forums.sketchucation.com/viewtopic.php?t=37165:of9umm38][request] align view perpendicular to section[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=37094:of9umm38][Request] Component / Group Renamer - IDs[/url:of9umm38]
      url=http://forums.sketchucation.com/viewtopic.php?t=37031:of9umm38 Perspective 360 rotate[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=37024:of9umm38][Request] Report current Aspect Ratio[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=36945:of9umm38][Request] Force material deletion[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=36924:of9umm38][REQ] Scale Definition[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=36615:of9umm38][REQ] Group push-pull[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=36557:of9umm38]Layer Plug-in Reques[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=36445:of9umm38]Plugin Request: Show Keypress[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=36414:of9umm38]Plugin Request: Hide Bounding Box[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=36287:of9umm38]Request plugin fix[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=35887:of9umm38][request] Cline from Camera Eye to Sun[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=35717:of9umm38][Request] or is it Possible?[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=35558:of9umm38][Request] smooth deformation of selected volume[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=35379:of9umm38]Plugin request: set default color to back faces.[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=35223:of9umm38]Script/plugin request[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=35083:of9umm38][REQ] "Easy Outer Shell"[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=34893:of9umm38][request] divide faces[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=34882:of9umm38][Request] Distance from camera to object.[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=34603:of9umm38][ruby request] copy capture[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=34465:of9umm38]{REQ} .ass Exporter[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=34382:of9umm38]{REQ} Advanced Painter - Floor Generator[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=34215:of9umm38][REQ] drop and drape[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=34115:of9umm38]{REQ} lens shift image exporter[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=34056:of9umm38][REQ] Texture/material brush[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=34055:of9umm38][REQ] Pumped-up Group tool[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=34048:of9umm38][REQ]Automatic replace components randomly[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=34041:of9umm38]Request for Centering Plugin[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=34004:of9umm38][REQ] UV stick or UV remember.[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=33895:of9umm38][REQ] Triangles to quad ruby[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=33837:of9umm38][request] hold-fetch (3ds Max like) feature[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=33704:of9umm38]request for plugin[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=33481:of9umm38][REQUEST] bitmap to mesh with materials[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=33412:of9umm38][Req] Sketchup to Minecraft[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=33142:of9umm38][request] Oceanwave simulator with buoyance[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=33090:of9umm38][request plugin] offset line/face with specific distance[/url:of9umm38]
      url=http://forums.sketchucation.com/viewtopic.php?t=33023:of9umm38Plugin[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=33020:of9umm38]Face to Component - Request?[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=33008:of9umm38]Plugin Request? Copy Along Path with Orientation.[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=32979:of9umm38]Request[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=32928:of9umm38]How to rotate North in SU8 Free? (plugin request ?)[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=32920:of9umm38]Request: sewing template plugin[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=32899:of9umm38][REQ] layer selection plugins[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=32745:of9umm38]Plugin Request?[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=32609:of9umm38][Req] Style Consolidation[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=32557:of9umm38][req] tracing bitmaps?[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=32301:of9umm38][REQ] trilateration coords text tag[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=31992:of9umm38][Request] - Plugin to enable Macros !?[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=31951:of9umm38][REQ] Hide all toolbars at once (Windows)[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=31883:of9umm38][REQ] Project visible edges on a plane[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=31866:of9umm38][Req]Align XYZ[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=31865:of9umm38][REQUEST] Drop on a specified surface[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=31832:of9umm38][Req] shadow mapping plugin[/url:of9umm38]
      url=http://forums.sketchucation.com/viewtopic.php?t=31810:of9umm38 Tools in layers[/url:of9umm38]
      url=http://forums.sketchucation.com/viewtopic.php?t=31762:of9umm38 Scallop / Cloud Line conversion tool[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=31745:of9umm38]plug-in search/request[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=31527:of9umm38][Request] Simplify Contours; can it be modified to ...[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=31514:of9umm38][REQ] Drill + SNAP ?[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=31507:of9umm38][Request]Selection tool pick window[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=31505:of9umm38][Request] Zoom Window tool use the Active Axis[/url:of9umm38]
      url=http://forums.sketchucation.com/viewtopic.php?t=31432:of9umm38 Precise arc offset[/url:of9umm38]
      url=http://forums.sketchucation.com/viewtopic.php?t=31376:of9umm38 Brick & Tile Maker[/url:of9umm38]
      url=http://forums.sketchucation.com/viewtopic.php?t=31371:of9umm38 AutoLabel Plugin[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=31334:of9umm38]REQ: IMAGE TO POLY MAPPER[/url:of9umm38]
      url=http://forums.sketchucation.com/viewtopic.php?t=31196:of9umm38 Work Plane Tools[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=31101:of9umm38][Request]Radial lines 2D, 3D[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=31041:of9umm38]Plugin request - Exterior walls with joints[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=30952:of9umm38][request] Polygon count plugin[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=30931:of9umm38][REQUEST] fog control[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=30930:of9umm38][Plugin] Make Unique (find or request)[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=30911:of9umm38][Plugin Request] - Simplfy & Weld All[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=30715:of9umm38][request] SU to Word Press Button[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=30711:of9umm38][request][/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=30471:of9umm38][request] copy-doform-repeat[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=30359:of9umm38][Request] Sketchyphysics: Waving water?[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=30329:of9umm38][Request/Idea] On-Screen Keyboard Input[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=30263:of9umm38][Req]Gear Generator[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=30217:of9umm38][REQ] K-set Tilable Surfaces[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=30135:of9umm38][REQ] -- Hot Key[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=30112:of9umm38]Plugin search + plugin request[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=30084:of9umm38]PLUGIN REQUIRED: LINE GRADIENT QUERY[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=29805:of9umm38][Request] Building Heights[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=29765:of9umm38]Request plugin to help 2d drawing[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=29742:of9umm38]LEVEL DIMENSION TOOL REQUIRED[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=29634:of9umm38][Request] Draw lines,as if they were extruded with a circle.[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=29515:of9umm38][Request] - Component's options report[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=29463:of9umm38][Request] Lift Contours[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=29447:of9umm38][Request] - Import Model without layers ...[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=29375:of9umm38][REQUEST] Draw bounding box plugin[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=29341:of9umm38][REQUEST] Landscape covisibility plugin[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=29203:of9umm38]Request: Group to Component Plugin[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=28947:of9umm38]ambience / diffuse setting plugin request[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=28917:of9umm38][REQ] Change sun and shadows colour[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=28857:of9umm38][REQ] "place into tool"[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=28808:of9umm38][REQ] face normals[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=28752:of9umm38][REQ] label points with same X,Y Coordinates -pointcloud aid[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=28724:of9umm38]plugin required: paste on layer[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=28646:of9umm38][Req] Texture tools[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=28637:of9umm38][REQ] Select all connected faces with same orientation[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=28612:of9umm38][REQ] sun plugin[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=28580:of9umm38][REQ] Prefix Group/Component Names[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=28570:of9umm38]Request for plugin (Which Plugin Being Used?)[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=28544:of9umm38][Req]Assign Color to Scenes Tabs[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=28528:of9umm38]Toolbar request[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=28503:of9umm38]Open Clip request[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=28485:of9umm38][req]Tool to add or remove objects into(out) the group[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=28468:of9umm38][REQ] UV Cube and Planar mapping[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=28439:of9umm38]Simple Plugin Request - measuremeter[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=27947:of9umm38][Request] Control Sun location[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=27596:of9umm38]Req:SU to Zbrush Exporter[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=27416:of9umm38][REQ] Connecter[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=27347:of9umm38][Request] Textures applied to Scaled Group or Components[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=27322:of9umm38][Request] Helix following curves[/url:of9umm38]
      url=http://forums.sketchucation.com/viewtopic.php?t=27308:of9umm38 Place Component by UV?[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=27302:of9umm38][REQ] axes memory[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=27267:of9umm38][REQ] Fractal suggestion[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=27237:of9umm38][REQ] Place on Surface[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=27112:of9umm38]Request: draw segmented line[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=27069:of9umm38]request : last used tool[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=27007:of9umm38][REQ] trace shadows / export shadow contours[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=26988:of9umm38]Jitter request[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=26976:of9umm38][Request] Select vertical lines only[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=26957:of9umm38][Request] Edge loop Selection[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=26952:of9umm38][Request] Convert Curve to Circle[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=26942:of9umm38][REQ] Flatten lines Plugin[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=26923:of9umm38][REQ] PushPull Rotation[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=26730:of9umm38]req[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=26622:of9umm38]REQ - Isolate Selection[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=26620:of9umm38][Req] Check for N-Gons[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=26606:of9umm38][REQUEST] select lines by axis [Plugin][/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=26590:of9umm38][plugin request] Material overide per scene[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=26388:of9umm38][REQ] Folding around a circle...[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=26367:of9umm38][REQ] Material to Layer[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=26358:of9umm38][REQ] FBX Import[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=26347:of9umm38][REQ] Draw additional primitives[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=26343:of9umm38][REQ] Groove Maker[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=26307:of9umm38][Req} Cog Wheel Maker[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=26195:of9umm38][REQ] Tool to quick delete layers[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=25931:of9umm38]REQ: draw soft edges[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=25836:of9umm38]Request: Free-Rotate about a point[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=25759:of9umm38]Request- Dotted lines on xyz at a point on right clicking[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=25758:of9umm38][REQ] Follow me Multiple[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=25661:of9umm38][REQUEST] Reverse Curve Direction (Start and End)[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=25600:of9umm38][REQ] Delete or change range of materials[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=25411:of9umm38][Request] Sizing and Feedback of the SU Window Size[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=25355:of9umm38][REQ] project/unproject selected textures[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=25239:of9umm38]Question - Request: Materials CleanUp[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=39056:of9umm38][REQ] Drop zero after dimension comma[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=38614:of9umm38][REQ?] Functions in closed groups as if open[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=37374:of9umm38][REQ] VRML importer[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=36306:of9umm38]Requiring Socket on Mac crashes SU[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=35269:of9umm38]Menu, require and .rb files[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=35180:of9umm38][REQ] Tool to delete faces without thickness.[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=34220:of9umm38][Request] SU 6,7 & 8 : Version & Build & MR numbers[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=24586:of9umm38][REQ] manipulate camera by something like mover2 ?[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=33434:of9umm38][plugin request] Smallest bbox for 3d geometry.[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=33182:of9umm38]require 'sketchup'[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=16827:of9umm38]request_paint reverse[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=29892:of9umm38][REQ] Group different color than Component[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=26906:of9umm38]Set path for request dlls[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=13272:of9umm38][Req] Loft[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=24609:of9umm38]Ruby Sketchup Scriting - Help required! Losing hair![/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=25236:of9umm38][plugin request][/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=24426:of9umm38][REQ] Mix plugins to make windows better[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=24890:of9umm38][Request] ... Open Component[/url:of9umm38]
      url=http://forums.sketchucation.com/viewtopic.php?t=24831:of9umm38 Point inference On Edge when Using rotate tool[/url:of9umm38]
      url=http://forums.sketchucation.com/viewtopic.php?t=24698:of9umm38 Terrain generation plugin[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=24706:of9umm38]{REQUEST} Import Vectorworks 3D geometry to SU !!![/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=24625:of9umm38][Request] Select edges with material[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=24635:of9umm38][Request]Select alledges onXYZplan &Select triangulateedges[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=24517:of9umm38][Request] Internet in Sketchup[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=22677:of9umm38][REQ] Name Layer from a group existing[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=24264:of9umm38]Ruby Request[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=24254:of9umm38]Plugin Request[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=24207:of9umm38][REQ] triangulation ruby[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=23958:of9umm38][Request] Context Menu Organizer?[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=23283:of9umm38][REQ]texture curver[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=23787:of9umm38][REQ] Find and Patch the Hole[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=23797:of9umm38][Request] Create groups from multiple selections[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=23656:of9umm38][REQ] Boolean meta-blobs[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=23506:of9umm38]require 'sketchup.rb'[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=23434:of9umm38][REQ] Optimum Nesting boxes[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=23279:of9umm38][req] help with simple plugin[/url:of9umm38]
      url=http://forums.sketchucation.com/viewtopic.php?t=23257:of9umm38 What I (personally) would love for SU[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=22373:of9umm38][REQUEST] Select faces by bitmap RGB values[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=22844:of9umm38][REQ] replace construction point with component[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=23224:of9umm38]REQ: THICKEN ??[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=23070:of9umm38]script request -- drop to touch[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=23031:of9umm38][REQ] import in place[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=22816:of9umm38][REQ] Select internal edges[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=22915:of9umm38]request: Rset world Axes match GC Axse[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=22760:of9umm38][Request] Group > Select Instances > Convert to A Component[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=22713:of9umm38][REQ] Grasshopper for Sketchup[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=22718:of9umm38]Idea/request/plugin[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=22641:of9umm38][REQ] - Intersection Tools[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=22556:of9umm38][REQUEST] Custom Smoove[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=22497:of9umm38]component instance name. req help[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=22432:of9umm38][REQ] Colors inside Grow Plug by TIG[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=22433:of9umm38]How to save settings? Req. help, rubyscript.[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=22274:of9umm38]REQ - Toolbar Manager[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=22263:of9umm38][Request] APT ruby plugin "subscription" manager 4 SU needed[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=22149:of9umm38][REQ - Help] Division![/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=22101:of9umm38][req] Lapped textures[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=22075:of9umm38][Request] Reglue[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=22009:of9umm38][Request] 'Mass Reset Scale'[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=21967:of9umm38][request] true freehand[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=19093:of9umm38][Request] 'Clever Clay' mode[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=21917:of9umm38][Req.] remove instance duplicates plugin[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=21853:of9umm38]Export by layer script request[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=21894:of9umm38][Request] Clever Outliner[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=21851:of9umm38]Plugin request[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=21667:of9umm38][req] unique texture[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=21823:of9umm38][REQ] multiple flip along component's axis[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=21676:of9umm38]Req: woodwork.rb[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=21713:of9umm38][req]Hide certain layer on all other scenes[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=21592:of9umm38]Throw exception when required file does not exist?[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=21603:of9umm38]REQ: Project CAD Hatch[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=21473:of9umm38][Request] Update to layer and scene manager[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=21421:of9umm38][REQUEST] PlanarDraw[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=21389:of9umm38][REQ] Select textures in model from editor[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=21393:of9umm38]Transformation help req'd![/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=21335:of9umm38][Request] Randomize Plugin[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=21294:of9umm38]Question (request 😄[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=21374:of9umm38]REQ - Drape Points?[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=21242:of9umm38][Request] Addition to Flightpath script[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=21270:of9umm38]Request "Real-Line-Cross" Center point[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=21125:of9umm38][Request] Create an Edge or Surface using a Predefined Color[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=21241:of9umm38]request - digital watercolor engine[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=21195:of9umm38][Request]Define Segment Length Plugin[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=21162:of9umm38][Request] Script to produce window openings in walls[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=21069:of9umm38][REQUEST][/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20835:of9umm38]Plugin Request - Make Orthrographic Views[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20970:of9umm38][Request] Remove/Turn off Layer from all scenes ?[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20971:of9umm38][Request] - Save as Version 6 Button[/url:of9umm38]
      url=http://forums.sketchucation.com/viewtopic.php?t=20946:of9umm38 Different (2-4 or more) Viewports[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20930:of9umm38][Info/Request] Sections division[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20892:of9umm38][REQ] Materials Rename[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20856:of9umm38][Request]Open layers window[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20600:of9umm38][Request} Update to Pipe along Path >> Tappered Pipe[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20698:of9umm38][REQUEST] Multi-weld[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20625:of9umm38][REQ]Unested groups or components?[Resolved][/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20626:of9umm38]PLUGIN REQUEST: material by slope[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20476:of9umm38][Req] Export g-code for 5 axis cnc router[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20589:of9umm38][REQUEST] A plugin to load script on demand[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20599:of9umm38][Request] Custom Drape Tool ... TIG ???[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20162:of9umm38][Request] Macro Push/Pull Library[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20535:of9umm38][Request] Select Object > Select All Geometry on Same Layer[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20543:of9umm38][Request] Pipe Alone Path on None connected path[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20536:of9umm38][Question, Request] Component or Group Highligting[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20531:of9umm38][Req] Sketchup Skins[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20519:of9umm38][REQ] Roof tile ruby[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20474:of9umm38]Plugin-Request: draw-Wall[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20430:of9umm38][Request] - Dimension tool[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20206:of9umm38][REQ] Align Multi (Res) Drop Multi? Undrop Multi?(Res)[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20258:of9umm38][REQ] con. point at intersection[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20237:of9umm38]Question/Request - Is there a way to Filter Layers' ...[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=19932:of9umm38][Request] Testing on a Mac[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20143:of9umm38][Request] - Scene Tabs[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=11241:of9umm38][REQ] Displacement ruby[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=19204:of9umm38][REQ] Copy / Rotate / Blend[/url:of9umm38]
      url=http://forums.sketchucation.com/viewtopic.php?t=20099:of9umm38uniform scale on separated faces[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20093:of9umm38][REQUEST] Pick up layer from object[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=19600:of9umm38][REQ[ Extrude profile line along path[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20056:of9umm38][REQ] scene exporter[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20023:of9umm38][Request] POV Export / Import[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=20013:of9umm38][Req] Random Component/Group[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=19982:of9umm38][REQUEST]Saving scene properties[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=18035:of9umm38][Request] FBX import[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=19927:of9umm38][REQUEST] Plugin - Section moving tool[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=19882:of9umm38][REQ] TransparencySort Script[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=19636:of9umm38][REQ] Weld ALL selected lines[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=19530:of9umm38][REQ] Lock texture coordinates[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=19787:of9umm38]Ruby request: Redraw function for multiple selected DCs ..[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=19804:of9umm38][REQ] Curvespace for bezierspline.rb[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=14888:of9umm38]Plug-In Request / Idea - update HouseBuilder extension?[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=18227:of9umm38][req]Model Scrambler[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=19794:of9umm38][REQ] Reverse curve script[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=19750:of9umm38]Plugin Request- Ager[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=19363:of9umm38][REQ / IDEA] For a new section tool[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=19659:of9umm38][REQ] clean up multiple topos from earth[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=19691:of9umm38][REQ] fill area with instances of components[/url:of9umm38]
      url=http://forums.sketchucation.com/viewtopic.php?t=19566:of9umm38 Zoom to snap[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=19582:of9umm38][REQUEST] Directly Replace One Compenent with Another[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=19432:of9umm38][REQ] Make custom toolbar script[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=19336:of9umm38][Request] Is there a plugin to save/set my icons & palletes[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=10686:of9umm38][REQ] HTML Viewer for SketchUp[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=15952:of9umm38]Rigging ruby [req][/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=19227:of9umm38][REQ]Extrusion lines along a vector[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=19130:of9umm38][REQ] New Rotate Tool = Rota-Scale?[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=19024:of9umm38][Request} Search Layer Names and Object Names[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=18891:of9umm38][request] Plugin UVTools for cube[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=18948:of9umm38][Request] Plugin needed- origin of radius[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=18903:of9umm38]'require' problem with RBS[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=18817:of9umm38][Request] Dimension and Leader Text - Toggle Visibility[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=18671:of9umm38][Request] Force new face Front or Back ?[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=18664:of9umm38]AUTO-CUT faces / objects - ruby request[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=18728:of9umm38][REQ] Convert Tutorial to Script[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=18663:of9umm38]BOX SELECTION - ruby request[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=18527:of9umm38][REQ] Select ALL by material[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=18075:of9umm38][req] soften/divide geometry (by angle)[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=18381:of9umm38]REQ: mass material exporter[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=18377:of9umm38]REQ: Palette docking[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=13922:of9umm38][REQ] Arrowhead Maker tool ?[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=18340:of9umm38][Request] Move Guidelines, Move Points >> TIG?[/url:of9umm38]
      url=http://forums.sketchucation.com/viewtopic.php?t=18257:of9umm38 Model Scrambler, sort of[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=18200:of9umm38][REQ]Grow by TIG[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=15826:of9umm38][Request]: SunPositionGizmo.rb[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=18094:of9umm38][REQ] Macro / Action Recorder[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=18110:of9umm38][REQ] cloth tool[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=17151:of9umm38][REQ] -- BEND.rb[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=17913:of9umm38][Req] Select all connected same material[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=17782:of9umm38][REQ] Script to Push/Pull a face to a point above it?[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=17687:of9umm38][REQ] Disable Inferencing.[/url:of9umm38]
      url=http://forums.sketchucation.com/viewtopic.php?t=17585:of9umm38 automatic zoom[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=17610:of9umm38]"include" vs "require"[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=17576:of9umm38][REQ] components to groups script[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=17471:of9umm38][REQ] Fold or Bend?[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=17563:of9umm38][req] orient to axis?[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=17579:of9umm38][REQ] Window Splitter[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=17490:of9umm38]Req: Scale group of items around each center[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=17377:of9umm38][req] Z-depth image exporter[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=17467:of9umm38][REQ] Plugin to rotate textures 90°[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=17424:of9umm38][Request] add/subtract to group/component ,Ruby[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=17369:of9umm38][REQUEST] DEM exporter[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=17303:of9umm38][REQUEST] SU 7 to SU6[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=16353:of9umm38][Requested Plugin] Lathe tool[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=17311:of9umm38][ruby request] edges to layer[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=17275:of9umm38]Exploded circle not circle anymore... (request code or idea)[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=17193:of9umm38][REQ] .ai import[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=17120:of9umm38][REQ] - Weld Lite - attn:RickW[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=17166:of9umm38][REQ] Force stop[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=17122:of9umm38][req] pencil construction[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=17088:of9umm38][Request] toggle between selected layer[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=17000:of9umm38][Request] Transformation rotation for animation help[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=17065:of9umm38][REQ] Plugin to scale collection of components[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=17035:of9umm38][REQ] PurgeAllHidden[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=16862:of9umm38][REQUEST] Automatic drawing of vertical lines[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=16665:of9umm38][REQ]: Select All Objects With 'Default Material'[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=16713:of9umm38][Req] Face Stitcher[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=16689:of9umm38][REQ] Advanced Custom Toolbars[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=16586:of9umm38]Request - Fixed square metre[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=16641:of9umm38][REQ] Plugin to make Doors and drawers[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=16649:of9umm38][REQ] Angular Dimension[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=15522:of9umm38]Request - Email Model function in the SU File menu[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=16451:of9umm38]Request Plugin: Annotate the Locations.dat file[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=16428:of9umm38]REQ: For VRAY users, Material Grabber ===>[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=16388:of9umm38][ruby request] anti-coma[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=13083:of9umm38][Req] Texture Corrector.... PLEASE[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=16240:of9umm38]onClick ruby[Request][/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=13365:of9umm38]Line on surface removal plugin (Request)[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=15588:of9umm38]Request - A modified Tape Measure tool[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=15596:of9umm38][Request]: RotateByCenterpoint.rb[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=15521:of9umm38]Question / Request: Setting the Scenes' "Properties to Save"[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=15436:of9umm38]¨[REQUEST]: DropByGravity.rb[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=14980:of9umm38][Req] Viewporter[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=12965:of9umm38][REQ] follow me rotate[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=15339:of9umm38][ruby request] "always face camera" generator[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=15207:of9umm38][REQ] Export by layers[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=15171:of9umm38][Req] Keys to Toggle Snaps[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=15097:of9umm38][REQ] Time dependant component[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=15130:of9umm38]Require (include) system libraries[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=15070:of9umm38][REQ] load textures automatically in files .3ds imported[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=15055:of9umm38][Ruby Request] - Duplicate Layers & Contents[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=13247:of9umm38][Req] Similar groups to Components[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=14939:of9umm38][REQ] plugin to calculate list of objects with price[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=14794:of9umm38]Request; Ruby for making SU tutorials[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=14704:of9umm38][REQ] POLY SIMPLIFIER[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=14670:of9umm38]Sketchybevel not working - help requested[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=14662:of9umm38][REQ] Print view as seen while editing a component or group?[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=14554:of9umm38][REQ.] ... XREF in Toolbar Form[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=14539:of9umm38][req] webdialog[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=12761:of9umm38]REQ: ANother camera[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=14187:of9umm38]Req script to draw squares by specifying the area[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=14355:of9umm38]Help! Ruby and Sketchup information required!!![/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=14337:of9umm38]REQ: some help[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=10555:of9umm38][REQ] Convert ALL components to groups?[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=14101:of9umm38]REQ : Equally spacing[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=13593:of9umm38][request] cad layer export[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=13988:of9umm38]{REQ} Grow selection[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=14002:of9umm38][REQ] Sketchup Web Exporter mod?[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=13963:of9umm38][Req] lasso selection tool[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=13953:of9umm38][REQ] Scale to Offset[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=13825:of9umm38][REQ] Components by toolbar[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=13761:of9umm38][Req] Bump or Collide[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=13700:of9umm38][request] Again, web3D application?[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=13245:of9umm38]req : arc extend , trim[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=13670:of9umm38][REQ] SketchUp LOCK[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=13585:of9umm38][Req] Curve Divider[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=13690:of9umm38][REQ] Shadow intersect[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=13597:of9umm38][Request] Rotation for Individual Objects[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=13534:of9umm38]Request: modifiy DelConLInesOnly.rb DelConPointsOnly.rb ❓[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=13306:of9umm38][REQ] Appcasting or Sparkle for automatic updates of rubies?[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=13535:of9umm38]Request: Glose gaps from Autocad import[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=13390:of9umm38][REQ] Idea For A Ruby Script - Lineweights[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=13327:of9umm38][Req]wrapping projected material on multilevel component[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=13310:of9umm38][REQ]shortcut_monitoring_script[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=13219:of9umm38][Req] Rippled surfaces[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=13067:of9umm38][REQUEST] Purge Toolbar Button[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=12982:of9umm38][REQ] 360 camera snapshot[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=12868:of9umm38][REQ]push/pull/scale[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=12845:of9umm38][REQ] Component to layer[/url:of9umm38]
      url=http://forums.sketchucation.com/viewtopic.php?t=12916:of9umm38 2D Drafting Tools[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=12765:of9umm38][REQ] - SANDBOX EXTENTIONS (A request to all the rubie GODS)[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=12864:of9umm38][REQ] Select Tools (Inverse & Polyline)[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=12711:of9umm38][REQ] - Import Large Image[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=10757:of9umm38][REQ] Double Offset[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=12493:of9umm38][Req] Preserving UV information[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=11523:of9umm38][REQ] Magic Wand[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=12476:of9umm38]A request to TBD and/or Didier Bur[/url:of9umm38]
      url=http://forums.sketchucation.com/viewtopic.php?t=12539:of9umm38 IMPORTER / EXPORTER[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=11086:of9umm38][REQ] Gray Scale?[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=12466:of9umm38][Req] Auto Follow Me[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=12475:of9umm38][REQ] 3D-CPOINT[/url:of9umm38]
      url=http://forums.sketchucation.com/viewtopic.php?t=12473:of9umm38 random component spray confined inside polyline (face)[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=12436:of9umm38][REQ] Draw circle tangent to lines[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=12298:of9umm38][REQ] wire lines to tubes[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=12279:of9umm38][Request] SketchUp to .mi exporter[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=12288:of9umm38][REQ] Material Modifier[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=11153:of9umm38][REQ] Benchmark script[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=12183:of9umm38]REQ--Inferring an midpoint for mirroring.[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=12187:of9umm38][REQ]Chat Plug-in[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=12103:of9umm38][Request] - Shadows[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=12104:of9umm38][Request] - Reloading a CD Import[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=11206:of9umm38][REQ]: record camera movement --> into scenes[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=11836:of9umm38][REQ] Ruby, “report-back”[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=11627:of9umm38][Req] Toggle Units[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=11487:of9umm38][req] sketch fillet tool[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=11552:of9umm38][REQ] Reset Scale of Selected[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=11519:of9umm38][req] double line tool[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=11240:of9umm38][REQ] Advanced drape tool[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=11337:of9umm38][REQ] two ideas for plugs[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=11325:of9umm38][REQ] stitching aces together[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=11286:of9umm38][REQ] Centerpoint to Table[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=11262:of9umm38][REQ] dwg import segment adjust[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=11145:of9umm38][REQ] XraySelection reversion[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=10981:of9umm38][REQ] Segment Follow Me[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=11002:of9umm38][REQ]Animated GIFs in Sketchup[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=11000:of9umm38]plugin request - part line geometry[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=10912:of9umm38][REQ] free_hand knife tool[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=10835:of9umm38][REQ] Control Image Export Size[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=10690:of9umm38][REQ] Splitting screen for render[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=10800:of9umm38][REQ] Space Navigator: dynamic center of rotation[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=10606:of9umm38][REQ] perpedicular movement for entities[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=10558:of9umm38][REQ] sketchup image sampling[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=10537:of9umm38]a ruby request: select similar[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=10493:of9umm38][REQ] Multiple copy[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=10425:of9umm38]REQUEST: Scene rubie[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=10396:of9umm38]Request: window teleporter[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=10071:of9umm38]Request for RUBY[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=9476:of9umm38]Script request find geometry and replace with component[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=9718:of9umm38]Request plugin :Trilateration ruby[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=9671:of9umm38]Request Plugin: ABORT operations in ESC[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=9563:of9umm38]Simple ? dooropening request[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=9617:of9umm38]Combine Scene Tabs...Video Short..Request[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=9554:of9umm38]Request about materials[/url:of9umm38]
      url=http://forums.sketchucation.com/viewtopic.php?t=9438:of9umm38 A SkIndigo-like ...[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=9324:of9umm38][Requiest] Opener Metric[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=9272:of9umm38][Request] Rectangle Elevated[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=8547:of9umm38]A More Sophisticated Animation Script request[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=8066:of9umm38]Script Request/Idea - MultiConstruction lines[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=5779:of9umm38]Request for a new script, Notes[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=3877:of9umm38]Automatic projected mapping script request[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=3836:of9umm38]Camera Tools request[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=3261:of9umm38]TubeAlongPath.rb and Square Ducts - Request (Attn: TIG)[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=3039:of9umm38]VolumeCalculator Enhancement Request Attn: TIG[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=3024:of9umm38]Request: Delete Construction Entities Script[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=1959:of9umm38]VolumeCalculator Script - Modification Requests Attn: TIG[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=1827:of9umm38]Request: Automatically add ConstructionPoint at Center of Ci[/url:of9umm38]
      [url=http://forums.sketchucation.com/viewtopic.php?t=1711:of9umm38]REQUEST (perhaps needs another subsection?)[/url:of9umm38]
      • david_hD Offline
        david_h
        that's quite a list. . .
        I'll get right on it. 😉 😒
        • mitcorbM Offline
          mitcorb
          A quick scan suggested that some requests were indirectly fulfilled. That is, reading the requests suggested such tools as Free Rotate by TIG, for instance, and a couple of others.
          EDIT: And, thank you, Jim this will be interesting reading.
          • Dan RathbunD Offline
            Dan Rathbun
            Might help if the list were brought into a spreadsheet, and categorized, such as "Construction Lines/Points", "Importers", "Exporters", etc.
            I'm not here much anymore.
            • Chris FullmerC Offline
              Wow, this is cool. I didn't see this when you posted it Jim. Very cool.
              Chris
              All my Plugins I've written
              • pbacotP Offline
                Thanks! Now, list ones that are all or partially provided already. 😄
                  Do you mean an update to that list showing which of those have since been created? Or did you just want a complete list of all plugins hosted on SCF? The complete liste exists:
                  http://sketchucation.com/forums/viewtopic.php?p=250026
                  Chris
                  • pbacotP Offline
                    Chris
                    I was only kidding. Assembling 500 posts is perhaps enough! Yeah, I meant of these, I wonder how many are actually taken care of. I guess that's a job for me then 😕
                    I read one where TIG was about to post a solution but the link wasn't there.
                      Cool a second chance for some ones! 😎
                        @pbacot said:
                        ...I read one where TIG was about to post a solution but the link wasn't there.
                        Perhaps there was already a solution, or I posted a full blown solution in another thread 😕
                        although I would usually post a link to that...
                        The only one I can recall was ages ago - EarthMover's 'tiling' request, which was superseded by events, when several example scripts/ideas came 'from others'... 😮
                        I'd be interested to learn which specific 'request' this was... senility must be setting in 😒
                        • pbacotP Offline
                          http://sketchucation.com/forums/viewtopic.php?t=19600
                          it's a lot like this one: http://sketchucation.com/forums/viewtopic.php?t=20065 😄
                          No really I just use "by rails" so much I forgot this simple one at the top is exactly it 😒
                          So while there are many requests -- many, if not most, have been answered.
                            So what you are saying is that there have been many requests, but only a percentage of these have never been answered. If I get embroiled in a request I do try and end with a resolution, or "It's not possible...".
                            So who is to produce the list of [REQ] posts that have been answered / unanswered ?
                            And why ?? I don't really see a purpose - otherwise why not do the same for requests for help with say the Move tool, or Arc ?
                              Dan Rathbun
                              (1) Can moderators set a topic to "Solved" against a certain post, with the new "solution feature" (green check button) ??
                              (2) There IS a search feature to find "Unsolved Posts."
                              Is there one to find "Solved Posts" ??
                              (3) Can Jim's scraping script be modified to filter "Unsolved" from "Solved" ?
                                Dan Rathbun
                                The answer to (1) I'd say is YES.
                                I personally changed the title prefix from "[Issue]" to "[Closed]", but it was Gábor that actually marked it solved. (He reminded me of the "solution feature" in doing so.)
