    500 Plugin Requests
    14 Posts 8 Posters 2.4k Views 8 Watching
    • mitcorbM
      mitcorb
      A quick scan suggested that some requests were indirectly fulfilled. That is, reading the requests suggested such tools as Free Rotate by TIG, for instance, and a couple of others.
      EDIT: And, thank you, Jim this will be interesting reading.
      • Dan RathbunD
        Dan Rathbun
        Might help if the list were brought into a spreadsheet, and categorized, such as "Construction Lines/Points", "Importers", "Exporters", etc.
        I'm not here much anymore.
        • Chris FullmerC
          Wow, this is cool. I didn't see this when you posted it Jim. Very cool.
          • pbacotP
            Thanks! Now, list ones that are all or partially provided already. ๐Ÿ˜„
            • Chris FullmerC
              Do you mean an update to that list showing which of those have since been created? Or did you just want a complete list of all plugins hosted on SCF? The complete liste exists:
              404 Not Found
              (sketchucation.com)
              • pbacotP
                404 Not Found
                (sketchucation.com)
                I was only kidding. Assembling 500 posts is perhaps enough! Yeah, I meant of these, I wonder how many are actually taken care of. I guess that's a job for me then ๐Ÿ˜•
                I read one where TIG was about to post a solution but the link wasn't there.
                  Cool a second chance for some ones! ๐Ÿ˜Ž
                    @pbacot said:
                    ...I read one where TIG was about to post a solution but the link wasn't there.
                    ๐Ÿ˜ฒ
                    Perhaps there was already a solution, or I posted a full blown solution in another thread ๐Ÿ˜•
                    although I would usually post a link to that...
                    The only one I can recall was ages ago - EarthMover's 'tiling' request, which was superseded by events, when several example scripts/ideas came 'from others'... ๐Ÿ˜ฎ
                    I'd be interested to learn which specific 'request' this was... senility must be setting in ๐Ÿ˜’
                    • pbacotP
                      404 Not Found
                      (sketchucation.com)
                      it's a lot like this one: http://sketchucation.com/forums/viewtopic.php?t=20065 ๐Ÿ˜„
                      No really I just use "by rails" so much I forgot this simple one at the top is exactly it ๐Ÿ˜’
                      So while there are many requests -- many, if not most, have been answered.
                        @pbacot said:
                        404 Not Found
                        (sketchucation.com)
                        So what you are saying is that there have been many requests, but only a percentage of these have never been answered. If I get embroiled in a request I do try and end with a resolution, or "It's not possible...".
                        So who is to produce the list of [REQ] posts that have been answered / unanswered ?
                        And why ?? I don't really see a purpose - otherwise why not do the same for requests for help with say the Move tool, or Arc ?
                        • Dan RathbunD
                          Dan Rathbun
                          (1) Can moderators set a topic to "Solved" against a certain post, with the new "solution feature" (green check button) ??
                          (2) There IS a search feature to find "Unsolved Posts."
                          Is there one to find "Solved Posts" ??
                          (3) Can Jim's scraping script be modified to filter "Unsolved" from "Solved" ?
                          • Dan RathbunD
                            Dan Rathbun
                            The answer to (1) I'd say is YES.
                            I personally changed the title prefix from "[Issue]" to "[Closed]", but it was Gรกbor that actually marked it solved. (He reminded me of the "solution feature" in doing so.)
