    Vray rendering issue with light/shadow
    renderpluginsextensions
    6 Posts 4 Posters 3.1k Views 4 Watching
    • W
      wtang
      I'm somewhat of a vray rendering noob. I've modelled a scene which I'm now trying to render, but I'm not getting anything near the results I'd expected. I've tried googling the issue but can find no obvious solution and outcomes have not differed greatly despite my tinkering with the settings.
      Basically I'm trying to render a scene which is set on the top of my builing; I've created a large number of objects on top of a frame I've designed to simulate the light and shadow effect of light passing though foliage - the unrendered scene shows the light/shadow that I want
      http://i1133.photobucket.com/albums/m589/tangtastic1/1.jpg
      but when I render I get a scene with apparently no light, or at the very least no light/shadow detail
      http://i1133.photobucket.com/albums/m589/tangtastic1/2.jpg
      The render I have shown in image 2 is using default settings.
      Could someone advise please?
      • P
        pepa
        Interesting..try pick on default light, or try reverse faces on squares in celling.
        http://jsvizualizace.daportfolio.com/
        • andybotA
          andybot
          try reloading the default vray settings. Should have the sunlight show up. Did you try loading a visopt file? the older ones available don't always work in the current version of vfsu
          • W
            wtang
            Thanks for your replies.
            I tried reloading default settings, and switching off the squares. This is what I got:
            http://i1133.photobucket.com/albums/m589/tangtastic1/1-1.jpg
            Not too sure why, but it appears that there is no light source set in the rendered scene, although it shows when it is unrendered. Could someone advise how I fix this so I get what the light/shadow details in my sketchup model in my vray render?
            Thanks,
            Will
            • W
              wtang
              Fixed.
              For anyone else having the same problem, you go into:
              vray options > Environment > Texture editor for GI settings > Set 'Sunlight' for Sun
              Thanks to Pepa and Andybot for their input,
              Will
              • O
                oxig3n
                i had the same promblem
                in the camera options you can unmark camera physics
                or you can adjust the 'f' 'iso' 'shutter speed'
                lower a bit the 'f' (to 6) and the shutter (60 to 120) , and raise a bit the iso (400 to 600)
                hope it helps and keep up the good work
