    Checking for a group?
    15 Posts 4 Posters 1.4k Views 4 Watching
      lothcat
      This seems like a silly question, but how do I check if something is a group? I simply can't figure it out.
      The user will click to run a function, and I need to make sure that what they clicked on is a group so the function can run properly. I've looked through the API but it was as useless as ever.
      • TIGT Online
        xxx.class==Sketchup::Group [EDIT: corrected typo!]
        returns true/ false
        To find 'xxx' you have various options...
        Depends how the user is to choose the object.
        Preselected it's from
        xxx=model.selection[0]
        If picked with the mouse [within a tool] it's more complex... you make a pickhelper and check what is picked - http://code.google.com/apis/sketchup/docs/ourdoc/pickhelper.html
        You then need to mess on with picked_element, best_picked, all_piked etc to see if there's a group in there as expected... πŸ˜•
        • Dan RathbunD Offline
          Dan Rathbun
          @tig said:
          xxx==class.Sketchup::Group
          returns true/ false
          He means:
          xxx.class == Sketchup::Group
          returns boolean
          The class() method is a Core Ruby instance method, defined within class Object (the supremeclass of all classes,) and so is inherited by all classes, and their subclasses.
          Make sure you have the CHM for the Core Ruby classes and methods:
          RUBY PROGRAMMING REFERENCES - CHM format
          or use the online reference:
          Ruby Documentation 1.8.6 Core
          I'm not here much anymore.
          • TIGT Online
            Thanks Dan, another typo - more haste less speed...
            I've fixed the original... πŸ˜’
              lothcat
              Thanks!
              • artmusicstudioA Offline
                artmusicstudio
                hello,
                i went thru all snippets,
                but
                how can i check, if a group @NAME
                exists or not in the actve model.
                situation
                i create a group NAME by ruby
                then it either is deleted or not
                whith the next call ruby shall check, if group NAME is there
                if not, create it
                if so, delete and create it new
                my trial:
                entities = @NAME.entities
                entity1 = entities[1]
                status = entity1.valid?
                unless status == true
                   model = Sketchup.active_model
                   @NAME.erase!
                reports an not existing group, so no check is possible
                tahnx for helping on this
                stan
                • TIGT Online
                  A simple
                  group.valid?
                  or - assuming the group is named 'xxx'
                  group=nil
                  Sketchup.active_model.definitions.each{|d|
                  next unless d.group?
                  if d.instances[0].name=="xxx"
                  group=d.instances[0]
                  break
                  or
                  group=nil
                  some_entities.grep(Sketchup::Group).each{|g|
                  if g.name=="xxx"
                  group=g
                  break
                    artmusicstudio
                    hi tig and yes,
                    @group_STAIR.erase! if @group_STAIR.valid?
                    works perfect.
                    another advantage: when i generate my group and copy it manually to the desired place
                    and then call the ruby again, the original is beeing deleted and the copy remains.
                    that is, what i wanted to achieve: when the user is satisfied with the result, he can either make a copy or make a component out of the group.
                    next step is done!
                    thanx a lot
                    stan
                    ps: (on the other hand i was not sure in example 2 and 3, why they did not work for me, i still investigate, must be the NAME definition, i think).
                      Dan Rathbun
                      In Ruby, only constants are ALL_UPPERCASE
                        artmusicstudio
                        hi dan, have to correct it ( was only for me to see it better while working on it), thanx. (and i already study the files, you recomend for newbie's...but it's a lot to learn, of course)
                        and i have to correct my previous statement:
                        my "checking" code does not work in a new opended file. it again reports a deleted group, while searching for it.
                        but, as soon as i create the first group and the activate the checking-line, it works.
                        so now a question:
                        is there a way to define 1 variable (true or false) ON LOAD ?
                        so this variable would only be "true" when sketchup is opened and before my ruby script runs for the first time (i could overwite it then for the active session)?
                        then i could run the checking code "unless onload == true " or something like that.
                        ragrds stan
                        • TIGT Online
                          How is your code 'encapsulated' ?
                          In a module or a class ?
                          In a module use an instance variable @onload=true within the module but outside of any methods will set it as true initially, as the code is first loaded as SketchUp starts up.
                          Later when you run you first method in that module @onload=false ...
                          The @onload value in remembered across instances of that code during that session of SketchUp.
                          For a class [Tool etc] you need a @@onload prefixed class variable to keep it enduring across uses of that class. Again define it initially outside of any class methods but inside the class's code.
                          When you finish processing and exit your method you can might want to reset @onload=true etc ? It depends on what it is used for etc...
                          Because the user could open a new or existing SKP, and that would continue to use your already-loaded/reset code you might want to construe an AppObserver that resets @onload=true whenever such things change ?
                          However, KISS - the simplest way to think about this is to test for group.valid? before trying to do anything to it. It's a basic trap in scripts to trap for anticipated possible failures:
                          do_something() if group.valid?
                          Another way to trap for unexpected failures is like this:
                          begin do_something() rescue do_something_different() end
                            Dan Rathbun
                            Also ...what we do is use the global methods defined in the file "sketchup.rb"
                            The two we use are named file_loaded() and file_loaded?()
                            require("sketchup.rb")
                            module AMS # <--<< your toplevel namespace
                              module ThisPlugin  # <--<< rename this
                                ### CONSTANTS
                                THISFILE = "#{Module.nesting[0]};#{File.basename(__FILE__)}"
                                ### MODULE VARS
                                @@loaded = false unless defined?(@@loaded)
                                ### PROXY CLASS (for this module)
                                class << self
                                  ### METHODS
                                  def loaded?()
                                    @@loaded = file_loaded?( THISFILE )
                                end # proxy class
                                ### define plugin specific classes or sub-modules here
                                class ThisTool
                                  ### define tool class callbacks here
                                ### FINAL RUN ONCE CODE
                                unless loaded?
                                  # set up dropdown menu here
                                  # and/or right-click popup menu
                                  # attach any initial observers here
                                  # mark this file as loaded
                                  file_loaded( THISFILE )
                              end # module ThisPlugin
                            end # module AMS
                              artmusicstudio
                              @ tig
                              hi tig, thanx,
                              with
                              def delete_model_zf
                              @putswitch = 0
                              	begin
                              	@group_stair.erase!
                              	rescue
                              it worked, as soon as i understood, that rescue can also be NOTHING, so the code runs thru end the method ends
                              @ dan, thanx,
                              this is still higher programming syntax (for my brain), i tried to encapsulate in
                              MODULE AMS
                              MODULE 01.rb // is it right to put hier 01.rb ??? (the work-name of the ruby)
                              MY CODE
                              END MODULE
                              END AMS,
                              but have errors. have to work it out! but i would like to put the ruby into a proper form for the first release / check. i'll get back to this later.
                                Dan Rathbun
                                module is a keyword, it must be all lowercase.
                                Module is a class name, it must be title case, if you refer to the class.
                                πŸ’­
                                  Dan Rathbun
                                  No you cannot use a Numeric expression as a Class or Module name. They must begin with alpha characters, and be title case.
                                  πŸ’­
