    Checking for a group?
    15 Posts 4 Posters 1.4k Views 4 Watching
      Thanks Dan, another typo - more haste less speed...
      I've fixed the original... πŸ˜’
        lothcat
        • artmusicstudioA Offline
          artmusicstudio
          hello,
          i went thru all snippets,
          but
          how can i check, if a group @NAME
          exists or not in the actve model.
          situation
          i create a group NAME by ruby
          then it either is deleted or not
          whith the next call ruby shall check, if group NAME is there
          if not, create it
          if so, delete and create it new
          my trial:
          entities = @NAME.entities
          entity1 = entities[1]
          status = entity1.valid?
          unless status == true
             model = Sketchup.active_model
             @NAME.erase!
          reports an not existing group, so no check is possible
          tahnx for helping on this
          stan
            A simple
            group.valid?
            or - assuming the group is named 'xxx'
            group=nil
            Sketchup.active_model.definitions.each{|d|
            next unless d.group?
            if d.instances[0].name=="xxx"
            group=d.instances[0]
            break
            or
            group=nil
            some_entities.grep(Sketchup::Group).each{|g|
            if g.name=="xxx"
            group=g
            break
              artmusicstudio
              hi tig and yes,
              @group_STAIR.erase! if @group_STAIR.valid?
              works perfect.
              another advantage: when i generate my group and copy it manually to the desired place
              and then call the ruby again, the original is beeing deleted and the copy remains.
              that is, what i wanted to achieve: when the user is satisfied with the result, he can either make a copy or make a component out of the group.
              next step is done!
              thanx a lot
              stan
              ps: (on the other hand i was not sure in example 2 and 3, why they did not work for me, i still investigate, must be the NAME definition, i think).
              • Dan RathbunD Offline
                Dan Rathbun
                In Ruby, only constants are ALL_UPPERCASE
                I'm not here much anymore.
                  artmusicstudio
                  hi dan, have to correct it ( was only for me to see it better while working on it), thanx. (and i already study the files, you recomend for newbie's...but it's a lot to learn, of course)
                  and i have to correct my previous statement:
                  my "checking" code does not work in a new opended file. it again reports a deleted group, while searching for it.
                  but, as soon as i create the first group and the activate the checking-line, it works.
                  so now a question:
                  is there a way to define 1 variable (true or false) ON LOAD ?
                  so this variable would only be "true" when sketchup is opened and before my ruby script runs for the first time (i could overwite it then for the active session)?
                  then i could run the checking code "unless onload == true " or something like that.
                  ragrds stan
                    How is your code 'encapsulated' ?
                    In a module or a class ?
                    In a module use an instance variable @onload=true within the module but outside of any methods will set it as true initially, as the code is first loaded as SketchUp starts up.
                    Later when you run you first method in that module @onload=false ...
                    The @onload value in remembered across instances of that code during that session of SketchUp.
                    For a class [Tool etc] you need a @@onload prefixed class variable to keep it enduring across uses of that class. Again define it initially outside of any class methods but inside the class's code.
                    When you finish processing and exit your method you can might want to reset @onload=true etc ? It depends on what it is used for etc...
                    Because the user could open a new or existing SKP, and that would continue to use your already-loaded/reset code you might want to construe an AppObserver that resets @onload=true whenever such things change ?
                    However, KISS - the simplest way to think about this is to test for group.valid? before trying to do anything to it. It's a basic trap in scripts to trap for anticipated possible failures:
                    do_something() if group.valid?
                    Another way to trap for unexpected failures is like this:
                    begin do_something() rescue do_something_different() end
                      Dan Rathbun
                      Also ...what we do is use the global methods defined in the file "sketchup.rb"
                      The two we use are named file_loaded() and file_loaded?()
                      require("sketchup.rb")
                      module AMS # <--<< your toplevel namespace
                        module ThisPlugin  # <--<< rename this
                          ### CONSTANTS
                          THISFILE = "#{Module.nesting[0]};#{File.basename(__FILE__)}"
                          ### MODULE VARS
                          @@loaded = false unless defined?(@@loaded)
                          ### PROXY CLASS (for this module)
                          class << self
                            ### METHODS
                            def loaded?()
                              @@loaded = file_loaded?( THISFILE )
                          end # proxy class
                          ### define plugin specific classes or sub-modules here
                          class ThisTool
                            ### define tool class callbacks here
                          ### FINAL RUN ONCE CODE
                          unless loaded?
                            # set up dropdown menu here
                            # and/or right-click popup menu
                            # attach any initial observers here
                            # mark this file as loaded
                            file_loaded( THISFILE )
                        end # module ThisPlugin
                      end # module AMS
                        artmusicstudio
                        @ tig
                        hi tig, thanx,
                        with
                        def delete_model_zf
                        @putswitch = 0
                        	begin
                        	@group_stair.erase!
                        	rescue
                        it worked, as soon as i understood, that rescue can also be NOTHING, so the code runs thru end the method ends
                        @ dan, thanx,
                        this is still higher programming syntax (for my brain), i tried to encapsulate in
                        MODULE AMS
                        MODULE 01.rb // is it right to put hier 01.rb ??? (the work-name of the ruby)
                        MY CODE
                        END MODULE
                        END AMS,
                        but have errors. have to work it out! but i would like to put the ruby into a proper form for the first release / check. i'll get back to this later.
                          Dan Rathbun
                          module is a keyword, it must be all lowercase.
                          Module is a class name, it must be title case, if you refer to the class.
                          πŸ’­
                            Dan Rathbun
                            No you cannot use a Numeric expression as a Class or Module name. They must begin with alpha characters, and be title case.
                            πŸ’­
