    Checking for a group?
    15 Posts 4 Posters 1.5k Views 4 Watching
    • Dan RathbunD
      Dan Rathbun
      @tig said:
      xxx==class.Sketchup::Group
      returns true/ false
      He means:
      xxx.class == Sketchup::Group
      returns boolean
      The class() method is a Core Ruby instance method, defined within class Object (the supremeclass of all classes,) and so is inherited by all classes, and their subclasses.
      Make sure you have the CHM for the Core Ruby classes and methods:
      RUBY PROGRAMMING REFERENCES - CHM format
      or use the online reference:
      Ruby Documentation 1.8.6 Core
      I'm not here much anymore.
        Thanks Dan, another typo - more haste less speed...
        I've fixed the original... πŸ˜’
        • L
          lothcat
          • artmusicstudioA
            artmusicstudio
            hello,
            i went thru all snippets,
            but
            how can i check, if a group @NAME
            exists or not in the actve model.
            situation
            i create a group NAME by ruby
            then it either is deleted or not
            whith the next call ruby shall check, if group NAME is there
            if not, create it
            if so, delete and create it new
            my trial:
            entities = @NAME.entities
            entity1 = entities[1]
            status = entity1.valid?
            unless status == true
               model = Sketchup.active_model
               @NAME.erase!
            reports an not existing group, so no check is possible
            tahnx for helping on this
            stan
              A simple
              group.valid?
              or - assuming the group is named 'xxx'
              group=nil
              Sketchup.active_model.definitions.each{|d|
              next unless d.group?
              if d.instances[0].name=="xxx"
              group=d.instances[0]
              break
              or
              group=nil
              some_entities.grep(Sketchup::Group).each{|g|
              if g.name=="xxx"
              group=g
              break
              • artmusicstudioA
                artmusicstudio
                hi tig and yes,
                @group_STAIR.erase! if @group_STAIR.valid?
                works perfect.
                another advantage: when i generate my group and copy it manually to the desired place
                and then call the ruby again, the original is beeing deleted and the copy remains.
                that is, what i wanted to achieve: when the user is satisfied with the result, he can either make a copy or make a component out of the group.
                next step is done!
                thanx a lot
                stan
                ps: (on the other hand i was not sure in example 2 and 3, why they did not work for me, i still investigate, must be the NAME definition, i think).
                • Dan RathbunD
                  Dan Rathbun
                  In Ruby, only constants are ALL_UPPERCASE
                  • artmusicstudioA
                    artmusicstudio
                    hi dan, have to correct it ( was only for me to see it better while working on it), thanx. (and i already study the files, you recomend for newbie's...but it's a lot to learn, of course)
                    and i have to correct my previous statement:
                    my "checking" code does not work in a new opended file. it again reports a deleted group, while searching for it.
                    but, as soon as i create the first group and the activate the checking-line, it works.
                    so now a question:
                    is there a way to define 1 variable (true or false) ON LOAD ?
                    so this variable would only be "true" when sketchup is opened and before my ruby script runs for the first time (i could overwite it then for the active session)?
                    then i could run the checking code "unless onload == true " or something like that.
                    ragrds stan
                      How is your code 'encapsulated' ?
                      In a module or a class ?
                      In a module use an instance variable @onload=true within the module but outside of any methods will set it as true initially, as the code is first loaded as SketchUp starts up.
                      Later when you run you first method in that module @onload=false ...
                      The @onload value in remembered across instances of that code during that session of SketchUp.
                      For a class [Tool etc] you need a @@onload prefixed class variable to keep it enduring across uses of that class. Again define it initially outside of any class methods but inside the class's code.
                      When you finish processing and exit your method you can might want to reset @onload=true etc ? It depends on what it is used for etc...
                      Because the user could open a new or existing SKP, and that would continue to use your already-loaded/reset code you might want to construe an AppObserver that resets @onload=true whenever such things change ?
                      However, KISS - the simplest way to think about this is to test for group.valid? before trying to do anything to it. It's a basic trap in scripts to trap for anticipated possible failures:
                      do_something() if group.valid?
                      Another way to trap for unexpected failures is like this:
                      begin do_something() rescue do_something_different() end
                      • Dan RathbunD
                        Dan Rathbun
                        Also ...what we do is use the global methods defined in the file "sketchup.rb"
                        The two we use are named file_loaded() and file_loaded?()
                        require("sketchup.rb")
                        module AMS # <--<< your toplevel namespace
                          module ThisPlugin  # <--<< rename this
                            ### CONSTANTS
                            THISFILE = "#{Module.nesting[0]};#{File.basename(__FILE__)}"
                            ### MODULE VARS
                            @@loaded = false unless defined?(@@loaded)
                            ### PROXY CLASS (for this module)
                            class << self
                              ### METHODS
                              def loaded?()
                                @@loaded = file_loaded?( THISFILE )
                            end # proxy class
                            ### define plugin specific classes or sub-modules here
                            class ThisTool
                              ### define tool class callbacks here
                            ### FINAL RUN ONCE CODE
                            unless loaded?
                              # set up dropdown menu here
                              # and/or right-click popup menu
                              # attach any initial observers here
                              # mark this file as loaded
                              file_loaded( THISFILE )
                          end # module ThisPlugin
                        end # module AMS
                        • artmusicstudioA
                          artmusicstudio
                          @ tig
                          hi tig, thanx,
                          with
                          def delete_model_zf
                          @putswitch = 0
                          	begin
                          	@group_stair.erase!
                          	rescue
                          it worked, as soon as i understood, that rescue can also be NOTHING, so the code runs thru end the method ends
                          @ dan, thanx,
                          this is still higher programming syntax (for my brain), i tried to encapsulate in
                          MODULE AMS
                          MODULE 01.rb // is it right to put hier 01.rb ??? (the work-name of the ruby)
                          MY CODE
                          END MODULE
                          END AMS,
                          but have errors. have to work it out! but i would like to put the ruby into a proper form for the first release / check. i'll get back to this later.
                          • Dan RathbunD
                            Dan Rathbun
                            module is a keyword, it must be all lowercase.
                            Module is a class name, it must be title case, if you refer to the class.
                            πŸ’­
                            • Dan RathbunD
                              Dan Rathbun
                              No you cannot use a Numeric expression as a Class or Module name. They must begin with alpha characters, and be title case.
                              πŸ’­
