    How can one calculate the smoothness of a bezier curve?
    11 Posts 5 Posters 943 Views 5 Watching
      Given a bezier curve, how can one calculate how many segments the curve needs in order to ensure a given smoothness (ideally defined by angle)
      I curious in case of optimizing a bezier curve to use as few segments as possible while visually keeping it smooth. For instance, a nearly straight curve only need 3-4 segments, while a curling loop needs lots more.
      • PixeroP Offline
        Pixero
        Not sure if this is what you want:
        http://devmag.org.za/2011/06/23/bzier-path-algorithms/
        http://www.efg2.com/Lab/Graphics/Jean-YvesQueinecBezierCurves.htm
          Interesting. Followed some links and found this: http://devmag.org.za/2011/04/05/bzier-curves-a-tutorial/
          Had one algorithm, but apparently there are instances where it fails...
          • Dan RathbunD Offline
            Dan Rathbun
            Wouldn't it depend upon the camera distance to the target?
            EDIT: I also seem to recall an earlier thread on this subject.
            Search: keywords=segments+bezier
            I'm not here much anymore.
              The smoothness will of course appear more or less depending on the camera. But that is of no concern. Just want to add more segments when the curve bends more.
              Ah, yes. Forgotten about that one. Didn't get any where with that one.
                Can't you simply check each of the curve.vertices [except the first and last ones] taking the two vectors from it to its immediate neighbors, which give you an angle and then it it's too small you add a vertex to divide that edge and relocate the vertices to soften?
                angle=120.degrees ### or whatever
                curve.vertices[1..-2].each_with_index{|v,i|
                  if v.position.vector_to(v[i-1].position).vector_between(v.position.vector_to(v[i+1].position)).radians < angle
                    ### do stuff to split the first edge at 'v' and
                    ### relocate 'v' and the new-vertex so angle is 'softened'...
                  Dan Rathbun
                  Curve.move_vertices( 3dpt_array )
                  Seems like we could use a new API instance method that used Edge.split for each segment of a curve, and then adjusted the new larger Curve.vertices array, using Curve.move_vertices, the question would be what would we what it's name to be?
                  Curve#smooth ?? Curve#smoothen ??
                  .. and what would it's arguments be?
                  Fredo ??
                    mac1
                    What criteria is used to determine smoothness is good enough?? RMS error or??
                      Dan Rathbun
                      The Sketchup UI limits the creation of Curves to segments of 2 .. 999.
                      If this limitation extends into the API, then an extention might be written thus:
                      class Sketchup;;Curve
                        # instance methods will be inherited by Sketchup;;ArcCurve
                        # coarseness
                        # returns Float in range 0.003 .. 1.000
                        #         for segments of 999 downto 2
                        def coarseness
                          (1000 -(self.count_edges - 2)).to_f/1000
                        end #def
                        # smoothness
                        #         for segments of 2 upto 999
                        def smoothness
                          (self.count_edges + 1).to_f/1000
                        end #def
                      end #class
                        I'm not talking about SketchUp entities. But a mathematically calculated Bezier curve - which later will be used to create geometry.
                        I want to be able to generate geometry with minimum segments whilst still retaining a good overall shape.
                          I was thinking that, from a user's point of view, one set a max angle. That the segments connecting each other would not exceed this max angle.
                          Though, I am open to other definitions.
