    Vray Displacement Problem
    renderpluginsextensions
    5 Posts 3 Posters 1.8k Views 3 Watching
      akinuri
      I'm having a problem with displacement in vray. When I want to render a close up displacement surface I get blurry, irregular edges. But if I zoom out and take render it's hard to notice them. You can see the images below. Does anyone know why this happens or how to fix it? VfSU 1.49.01 & SU 8
      • N Offline
        nomeradona
        can you also show your displacement map.
        visit my blog: http://www.nomeradona.blogspot.com
          akinuri
          Diffuse and Displacement textures
          • andybotA Offline
            andybot
            You should subdivide your surface into a grid. vray will triangulate your surface, and if it's a large surface, the displacement will not be as clean and take longer. You can also change your edge length value to a smaller number (though that can lead to long render times) Here is an example of what I mean. I used edge length of 1.5 and subdivs at 500.
            If the triangles are too stretched, you'll get that jaggy look, you can see a little bit of it in this image in the middle.
              akinuri
              Yay, this worked. Thank you I subdivided the surface and changed edge lenght to 2 and subdivision to 800. No weird edges πŸ˜„
              floor
              render1
              render2
