New to Sketchup - Engineer
Hi Im new to sketchup, just got pro8 and layout.I am working for an oil company as an R&D Engineer. I love it, and use the plungin Engineering tool box all the time. Any other plungins like this i should have? Or anything else? Thanks
Welcome.
There are many kinds of add-ons - it depends what it is you need...
I suggest you get familiar with the native tools and then think about scripts etc to help when you want to do stuff that'd be a chore [or maybe seems impossible!] manually...If you have a specific problem or requirement post a message with a clear title and explanation of what's up...
Hi Brett, hi folks.
Welcome from another engineer.
I also use the Engineering Toolbox a lot.
You may also try 3skeng. Their site is at:
http://www.3skeng.com/en/index.htm
Like they write, this is a conceptual tool since fittings are not exacts. For example, a 45° elbow will be similar to a 90° elbow cut in two, which is not exact. Tees can have any length while real tees have finite dimensions. The same goes for reducers.
That put aside, their system is amazing to use and allow you to sketch a whole layout in very little time. Combined with fittings obtained from the Engineering Tool Box and a few valves and equipements from the 3D warehouse and some other sites like Traceparts, you can produce relatively complex layout in such a short time that it may baffle your colleagues.
Just ideas.
Dear Brett,
You mind this thread interesting
You will also find some metric thread textures here
Hope this helps.
If you find out how to download the models (first link) then please let me know.
Kind regards,
Bob -
use Google Translate (probably best in chrome) to register in the forum, [I just used the same details as here]
wait for confirmation email [took 20 seconds]
use history to jump back to the models link
download...
Dear John,
Many thanks for that.
Kind regards,
Bob
Register LoginAdvertisement
