    Model this: Bold wooden table
    20 Posts 13 Posters 2.2k Views 13 Watching
    • soloS Offline
      solo
      Been a very long time since the last model challenge, I was approached to model something similar to this and thought it would be a great challenge for all you SU enthusiasts and a great learning challenge.
      I will supply a reference image or two and I'd like anyone with time, skills or a cool technique to give it a go (I'm most interested in the legs) What I want is something bold, almost over the top, imagine it being the focal point of a large room, an alter, an item you cannot help but be mesmorized by.
      Here is a brazillian table and Bernini's vatican columns, imagine this table being used in the Vatican, over the top with elements of Bernini and images below.
      Please join it and play, we can all learn from each other.
      http://www.solos-art.com
      • KrisidiousK Offline
        Krisidious
        this was one of the first components I made in SketchUp Years ago.
        as you can see it was an optical illusion, I didn't know how to make the spiral I wanted. 🤣
        By: Kristoff Rand
          bjornkn
          Here's a couple of baroque spirals with Shapebender.
            for intracaded spiral and helix
            Kito Raupp technic!
            [flash=560,349:jggcszsd]http://www.youtube.com/v/pNTetL3Udkc?fs=1[/flash:jggcszsd]
              Starling75
              Kito Raupp technic!
              wow .. very clever! nice
              http://www.starlingarch.cz
              • Alan FraserA Offline
                Alan Fraser
                And while we're on the subject of spirals, just a reminder about Spiralizer.
                It's still pretty good fun...even after the introduction of all the Rubies. Just drag the mouse over the parameter labels to see it interactively update.
                3D Figures
                  Not big and bold but there are barley twists on the legs. I used Draw Helix, Weld and Extrude edges by Rails
                  http://farm6.static.flickr.com/5038/5915398534_3fea7885d0.jpg
                  • charly2008C Offline
                    charly2008
                    used drawHelix and FollowMeandKeep and Classic Bezier Curve.
                    Charly
                    • oganocaliO Offline
                      oganocali
                      Well, I guess I would remove the snake teeth before I put this coffee table in my salon. I would not forget a coffee table that bit me 😄 . The model does need some extra work but I can not justify that. It is a vray render with native sketchup materials I only added a wee bit of reflection.
                      enjoy
                        jdadesignstudio
                        Hi guys,
                        I know this threads getting a little old, but thought Id give it a shot-havent played with the table top or textures yet, but I tried modeling the legs of the first table in your post Solo.
                        Looks like ill have to do 1 pic per post (sorry, im a long time reader on here, but first time posting).
                        Jon
                          jdadesignstudio
                          raw su pics
                            jdadesignstudio
                            bump...is anyone still interested in this thread?
                            • soloS Offline
                              solo
                              Sorry, it must have slipped back a few pages while I was not watching.
                              That is a very cool model, what did you use to make it? (plugins)
                                jdadesignstudio
                                here is the hidden geometry, it also shows the original geometry of the tapered spirals for the legs.
                                  jdadesignstudio
                                  No problem, thanks for the feedback! I used draw curves (I believe that is the name of it, Ive seen it called draw curves and draw metal), taper maker, bezier spline, and really those were the only plugins, besides follow me. The model is on my computer at my office-tomorrow Ill upload an image with the hidden geometry.
                                  -Jon
                                  EDIT: I also used the round corners plugin
                                    That's impressive. I'd removed Curvemaker but after seeing this I must give it a spin
                                      jdadesignstudio
                                      Thanks Rich, Id used it before for 2D spirals to then base objects off of (for example, I work for a university whose mascot is a ram, so I have done some models with spiral shaped ram horn themes), but for this model I had to use the 3D helix spiral, which is a bit tricky. What I wound up doing is making a very small helix (radius of 2" or less usually) to get the curve geometry how I wanted it, then I scaled the helix up to the proper size for the table, then finally added mass to it (by way of taper maker or follow me).
                                      • boofredlayB Offline
                                        boofredlay
                                        Wow cool. I missed those posts as well. Impressive modeling.
                                          Speaker
                                          A very great plugin that helps making spirals is Sketchy FFD. And in combination with Fredo scale, you can get really good results. Here is a video of me modeling a bottle, where I had a good use of this tehnique.
                                          http://www.youtube.com/user/latvietis1234
                                            jdadesignstudio
                                            Thanks Speaker, on one of my earlier trials I did use FFD, not quite how you are-I was using it to deform a tapered spiral after it was made (like squishing just the bottom 3rd, etc.).
