    FOLLOW ME TOOL..???
    5 Posts 3 Posters 329 Views 3 Watching
      ryanyoung
      I have created the following building using the following me tool (see attached).
      both gables are currently the same size - does anyone know the best way to make the gables
      different sizes? such that i have a sloping curved ridge line?
      I have tried using the scale tool just on the 2d surface of the gable but it has some weird effects.
      thanks,
      ryan
        I think I would use TIGs Extrude Tools for that. Create the outline of both gables as well as the ridge and eave curves. Then use Extrude edges by rails to get the faces. You could construct the sloped ridge line from the existing one if you want.
        that's a nice line style. What is it?
        • jeff hammondJ Offline
          jeff hammond
          an alternative to tig's extrude tools would be Curviloft..
          it has a function very similar to sweep1 commands in other apps..
          using curviloft's 'create loft junctions following a given path', you won't have to draw the curved/slanted ridge line (which will be a bit of a task in itself to get accurate).. just draw the two ends then a path line then run the tool..
          click pic -> bigger
          dotdotdot
            jeff hammond
            just an exaggerated example of using the above technique.. there's virtually zero work for the user.. the plugin does all the hard parts πŸ’š
            dotdotdot
              jeff hammond
              hey Dave,
              notice in his style that some of the shorter edges forming the curve don't show up.. i'll often try to apply styles to some of my drawings which are heavily curved etc and many of the lines won't show up..
              in fact, so many of the edges won't show up that i can't use the style even though i really like the look of it.
              is this something i can fix myself via a setting -or- is it something to do with the style itself?
              thanks.
              dotdotdot
