Toggling Styles
Is there a plugin that will toggle between Styles? I wish to toggle between two different styles and I was looking for any plugin that changed styles.
Thanks in advance
Ken
http://code.google.com/apis/sketchup/docs/ourdoc/style.html
and
http://code.google.com/apis/sketchup/docs/ourdoc/styles.html
cover what you can do with style and styles.
Changing between two named styles would be straightforward... -
Thanks you TIG
Well I have started reading, and will use your well written plugins for guidance.
Ken
Make scene1 with style1 but only save the style/fog settings (deselect camera etc)
Make scene2 with style2 doing the same thing.Switch between scenes.
(set animation to 0secs or else the styles will fade from one to the other. (or that may be desirable?))
Jeff
That what I do now. However, I have 5 scenes with 7 layers. I just was trying to limit the scenes and layers.
Thank you for the info
Ken
Register LoginAdvertisement
