    V -ray mess...
    renderpluginsextensions
    5 Posts 3 Posters 934 Views 3 Watching
    • tibetT Offline
      tibet
      hi,
      i´d like to create a brush stainless mail box in v-ray (1.48.89),
      but insted of this i´m getting drowned 🤣
      could you please somebody show me the right setting,
      because i can´t show this result to others. 😳 (see/ attach.)
      thanks!
      box.skp
      SU 2015 Pro on Win10 x64
      • broomstickB Offline
        broomstick
        I would try adding an HDR to the Background slot, so your brushed metal has something to reflect.. otherwise your surface will always reflect white!
        • tibetT Offline
          tibet
          wonderful idea, thanks!
          ...but, there´re plenty of them, which is the best?
          has anyone tried these ? i´ve downloaded some hdri files nature (Природа) but no chance to open zip files 😞
          it seems, they´re suitable just for 3d max.
          http://sw-in.narod.ru/hdrout.html
          http://forums.sketchucation.com/viewtopic.php?f=80&t=11410
          thanks!
          note. i thing, you can also get etraordinary results without hdri.
          magic formula is settings, making eg. glass effect like this i found on deviantart
          http://i54.tinypic.com/2ic1v08.jpg
          i´ve seen also a very beautiful ice lettering effect with tutorial , but i can´t find it anymore.
          • V Offline
            valerostudio
            Colored glass with that many curves is always going to render well IMO. A flat metal box is going to need some environment to reflect.
            A brushed stainless material needs Fresnel reflection with a high IOR, like 18 or so, a brushed map in the reflection exclusion map and a brushed bump map. Chaos (formerly ASG) has some good ones on their site if your registered. Try this one http://luzindirecta.luxisessentia.com/index.php/categories-menu/metal-menu/176-aluminium-brushed-01
            • tibetT Offline
              tibet
              hi valerostudio,
              thanks for your tips, very much appreciated.
              i´ll try to play with material and model, and we´ll see.
              cheers!
