    Changing Toolbar Image
    3 Posts 3 Posters 1.0k Views 3 Watching
    • A
      Anton_S
      Lets say I've created a new command:
      @toolbar=UI;;Toolbar.new("simulation")
      @playcmd=UI;;Command.new("play"){simulation.new}
      @playcmd.small_icon=@playcmd.large_icon="buttons/run.bmp"
      @playcmd.tooltip="Start simulation"
      @playcmd.status_bar_text="Start simulation"
      @playcmd.menu_text="Start!"
      @toolbar.add_item(@playcmd)
      @toolbar.show()
      Is there a way to change the icon of @playcmd any time I want? >
      When I click @playcmd button I wan't its icon to change to different icon. Like at first click the icon changes to pause.bmp, and at second click I want icon to change back to run.bmp.
      • TIGT
        The @playcmd is an class instance variable that only endures during that use of the class.
        Making it a @@playcmd class variable means that it's remembered for that session of Sketchup across instances of the class. You need to declare any such @@'s =nil in the body of the class code [near the start] and then set them to refer to objects within your methods etc...
        So theoretically you could [re]set the @@playcmd.small_icon() etc dynamically in response to a user clicking the button and/or the tool's @state changing etc...
        • Dan RathbunD
          Dan Rathbun
          There's no problem with changing the path to the image (no exception is raised,) it's just that the UI::Toolbar instance ignores the change. We've tried closing and opening the toolbar, but no effect.
          This is a change that needs to be implemented in the API using the relevant system calls on each platform. (I know how to do it on Windows making a Win32 call, but not on Mac.)
          So, this is a true wish... add my vote.
          I'm not here much anymore.
