    Error log problem!
    renderpluginsextensions
    3 Posts 2 Posters 3.8k Views 2 Watching
    • A
      amalskaer
      Hi guys
      Last night I was going to render something in google sketchup but then I got this error.
      I found the error log in programdata but I can't figure it out:
      About to make our qapp
      after make qapp
      Made it after UIManager.initialize
      C:\ProgramData\ASGVIS\Python26\Lib\site-packages\Ft\Xml\InputSource.py:346: DeprecationWarning: functions overriding warnings.showwarning() must support the 'line' argument
      FtWarning, 2)
      FtWarning: Creation of InputSource without a URI
      Entering renderArchive
      About to start readArchive - C:\ProgramData/ASGVIS/VfS/current_skp.xml
      0.488000 seconds is how long it took to read C:\ProgramData/ASGVIS/VfS/current_skp.xml
      0.003000 seconds is how long it took us to correct the file paths for all external texture file references in the scene.
      (to ensure this process goes as quickly as possible, please be sure all references to external texture files are correct prior to rendering)
      0.046000 seconds is how long it took to add the plugins to our renderer
      3.151000 seconds is how long it took to render
      3.303000 seconds is how long it took to read C:\ProgramData/ASGVIS/VfS/current_skp.xml
      0.025000 seconds is how long it took us to correct the file paths for all external texture file references in the scene.
      Traceback (most recent call last):
      File "C:\ProgramData\ASGVIS\Python26..\VfS\ASGVIS\vrayplugin.py", line 215, in add_to_renderer
      vray_param = param.to_vray_param(renderer)
      File "C:\ProgramData\ASGVIS\Python26..\VfS\ASGVIS\vrayplugin.py", line 92, in to_vray_param
      return self.value.to_vray_param(self.name, renderer, final_gamma )
      File "C:\ProgramData\ASGVIS\Python26..\VfS\ASGVIS\vraytypes.py", line 348, in to_vray_param
      return PyVRay.VUtils.DefStringParam(name, self.to_vray(renderer))
      TypeError: argument 2 of PyVRay.DefStringParam() has an invalid type
      • thomthomT
        Are you using the latest version? 1.49.01?
        • A
          amalskaer
          Pretty sure I am...
          I have no trouble with rendering another project but this one won't work..so I am guessing that it's errors in this file?
