    Ptex??
    19 Posts 6 Posters 1.9k Views 6 Watching
    • soloS
      solo
      Hey guys,I have no clue as to what can or cannot be done as far as c++ goes, and if or how it can be used with SU.
      I am always after a texturing/UV solution and I'd really like to know if Ptex can be implimented with SU.
      Ptex is not UV mapping, it's way better.
      see here:
      http://ptex.us/overview.html
      http://www.solos-art.com
      • B
        bjornkn
        I wouldn't think that adding Ptex into SU would be possible - at least not without a lot of compromises?
        OTOH you should be able to use Ptex in 3D-Coat and get your models into SU afterwards?
        http://www.youtube.com/watch?v=4137te68FP4
        • soloS
          solo
          What about stand alone, like the way we can export a texture for editing and save it and the changes transfer to SU, can we not do the same for a component or mesh to Ptex?
            Is it the paint feature you're after?
            • soloS
              solo
              Yes, the 'texal' concept is brilliant.
              • honoluludesktopH
                honoluludesktop
                Solo, did you down load the application, then run it? If you did, guess there wasn't a export / import feature. Looking at the "documentation", it seems that there is enough information to write an import / export program to produce a file that SU can read. However, I am not a expert on this matter, and it looks like a lot of work.
                • B
                  bjornkn
                  Yes you can, with 3D-coat. You paint with the Ptex texels in 3D-Coat and then export as UV mapped/baked object to import into SU. http://3d-coat.com/
                  Ptex only supports quads btw, afaik, which probably could be solved by the auto-retopology tools in 3D-coat v3.5 (I only have v2).
                  • soloS
                    solo
                    I guess that is a solution...kinda. at $350.00 πŸ˜‰
                      UU3D is $60 for the pro version and it imports and exports to skp. You can save UV maps to image, paint in PS and import back in to UU3D then expot to .skp. Steep learning curve though.
                      Have you ever used UV Layout?
                      • B
                        bjornkn
                        It's well worth the rpice πŸ˜„
                        The options at http://ptex.us/ , like C4D, Houdini, Mudbox etc won't be any cheaper for sure πŸ˜‰
                        Maybe MARI ?
                        • soloS
                          solo
                          lol, Mari at $2000.00, cool app but not needed in my workflow.
                          Rich, what do you mean by UV layout? I use Deep UV/paint every so often.
                            Surprised you haven't used UV Layout. If you wanna see it in action I can screen share
                            • soloS
                              solo
                              Yea I would, Skype?
                              • B
                                bjornkn
                                Guess I should have checked the price before mentioning it πŸ˜‰
                                Re 3D-coat - the price has increased a lot since I bought it a few years ago for $80, but so has the power of it. I think it's time for an upgrade soon πŸ˜„
                                I have never used it much because I've made mostly archviz, but it talks nicely with LW - and AFAIK it loads/saves Collada too. And there is a 30-day fully functional trial..
                                • N
                                  notareal
                                  What about blender,if I have understood correctly Nicholas Bishop has made a ptex patch http://www.nicholasbishop.net/
                                  Sorry, have not tried that...
                                  • soloS
                                    solo
                                    Blender? 😲
                                    Did you know that it's easier to get a commercial pilot license than learn Blender?
                                    • N
                                      notareal
                                      Then go with 3D-coat πŸ˜„ or there is Ptex plugins for major modellers (max, C4D, ...). You have Max?
                                      • thomthomT
                                        @solo said:
                                        Blender? 😲
                                        Have you looked at the new beta?
                                        • soloS
                                          solo
                                          I know there are numerous 3rd party apps that can achieve the UV solutions SU lacks, however I really like the Ptex system.
                                          I guess I'm hoping for a SU solution still, without needing to add more apps to my workflow, export, import, just a simple, easy solution.
