    Vray rendering problem!
    renderpluginsextensions
    8 Posts 7 Posters 10.1k Views 7 Watching
      amalskaer
      Hi guys
      So I just started this project and I think I am doing quite well...BUT when I try to render it's like the camera zoomed 800x away from the actual rendering point..
      I don't know what caused this problem but I hope someone can help me
      Here are the screens
      The actual rendering point I set
      The rendering result...
      • chonC Offline
        chon
        Hello,
        seeing your two renders, i think you are trying to render an axonometrical scene and VRay can render only perspective scenes. Put your SU scene in perspective mode and try a new VRay render ! πŸ˜‰
        Good luck !
        SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win10-64Bits
        • broomstickB Offline
          broomstick
          that's exactly what it is... you're viewing in parallel mode, but vray is rendering a perspective camera! Used to baffle me too πŸ˜„
            amalskaer
            @chon said:
            Hello,
            Good luck !
            Oh yeah you were right, I changed the camera to perspective and it helped! Thank you very much, kind sir.
            • H Offline
              Hayduke
              As a follow up - I have been looking for a long time for a trick to render Elevations and Axons. If I recall correctly, Twilight does this and I believe podium (and V-ray) at one degree FOV...
              Is there a way to change the camera settings in V-Ray to allow true parallel projection?
              • andybotA Offline
                andybot
                The only way currently to do true parallel projection is to turn off physical camera. Sorry 😞
                  ramsy_libra
                  Even I was experiencing the same problem! and the solution was this simple!!!hehe
                  Thanx a ton!!!
                  πŸ˜„ πŸ˜„
                    sketchyarchitect
                    I also had had this problem, and i spent the last hour trying to find what the problem was, I thought it was something to do with camera settings, lucky i stumbled upon this post β˜€
