    Dimension accuracy lower than 1/10th a millimeter
    layout
    5 Posts 2 Posters 1.4k Views 2 Watching
      beton04f
      Is there a way to achieve an accuracy lower than 1/10th a millimeter using DimensionTool ?
      Currently, I set unity to millimeter and I can set a display to "0,1".
      But I would like to obtain 1/100th of millimeter.
      Thanks for you help. Regards.
        As far as I remember, you can set accuracy to two decimal digits. So 0.01 should still work but 0.001 won't. I remember there was a (very technical) explanation for it but due to its technical reasons, I cannot remember.
          beton04f
          HI,
          in millimeter I can set 0,1
          in centimeter 0,01
          in meter 0,0001
          it's always 1/10th millimeter maximum accuracy, strange.
          Thanks.
            Yes, you are right, sorry. I should have checked first.
            (I always use centimetres so the two decimals may have come from that).
            Anyway, the "technical explanation" did really happen but I cannot remember the technical reason (as it was beyond my understanding anyway).
              beton04f
              Thanks.
              So, I'll make the PIGGGGGGGGGGGGGGGGGGGGGGG !!!
              I'll re-scale my model in SU by 100...
              Regards.
