    Ruby plugin?
    16 Posts 6 Posters 1.5k Views 6 Watching
      Thomas214
      I would like to write a plugin theat workes something like this:
      -Select multiple lines
      -Activate plugin
      -a box would appear were you would write the offset amount and hight
      -a offset line would be created
      -a face betweane the two offset lines would be created
      -used pushe/pull for hight
      -end
      I would like to se what SketchUp would do with the corners of the
      lines are diferent angles.
        Maybe a little concept image, because this plug is maybe yet existing πŸ˜„
          Thomas214
          There is an Example in the attachment of what I would like to do with it.
          From a line to a wall
            driven
            for something like this it's probably quicker and easier to draw [rectangle tool] the profile, select all lines and click followMe tool.
            there are lot of rubies that deal with more complex versions of this, but the standard tools can do quite a bit...
            draw profile, select line then followMe tool
              Thomas214
              [attachment=0:1tdufwpm]<!-- ia0 -->use_followMe.png<!-- ia0 -->[/attachment:1tdufwpm]
              This is somethin for my school project so to draw it this way it isn't an option πŸ˜„
                [attachment=0:3bwzyrmz]<!-- ia0 -->use_followMe.png<!-- ia0 -->[/attachment:3bwzyrmz]
                So write down the plan for your code...
                . check the model.selection contains some connected Edges (>>>path)
                . use a UI.inputbox() dialog to get the height
                . add a rectangle_face at start.position (p0) of first edge in path, calculating the other three points as p0=p1.clone; p1.z=p1.z+height etc using rectangle_face=entities.add_face(p0,p1,p2,p3)
                . use rectangle_face.followme(path) to extrude the new face along the path.
                . done
                  Thomas214
                  @tig said:
                  [attachment=0:2kbtp9i4]<!-- ia0 -->use_followMe.png<!-- ia0 -->[/attachment:2kbtp9i4]
                  . done
                  Hmmm what if I useEdge.all_connectedthen the code from the the plugin push/pull face I have?
                    Thomas214
                    I got this far
                    prompts = ["x:", "y:", "z:"]
                    defaults = [10, 20, 100]
                    input = UI.inputbox prompts, defaults, "Input data"
                    x = input[0]
                    y = imput[1]
                    z = imput[2]
                    model = Sketchup.active_model
                    ent = model.entities
                    sel = model.selection
                    entities = model.active_entities
                    pts = []
                    pts[0] = [0, 0, 0]
                    pts[1] = [x, 0, 0]
                    pts[2] = [x, y, 0]
                    pts[3] = [0, y, 0]
                    Add the face to the entities in the model
                    face = entities.add_face pts
                    I just happen to know that the second and third entities in the
                    entities objects are edges.
                    entity1 = entities[1]
                    entity2 = entities[2]
                    edges = entity1.all_connected
                    if (edges)
                    UI.messagebox edges.to_s
                    else
                    UI.messagebox "Failure"
                    faces = []
                    sel.each do |e|
                    	if e.is_a? Sketchup::Face
                             faces.push e
                     Sketchup.active_model.start_operation "Wall"
                    faces.each do |e|
                         ent.add_group e
                         e.pushpull (z)
                    		Sketchup.active_model.commit_operation
                    if( not file_loaded?('Wall.rb') )
                    UI.menu('Plugins').add_item('wall') {wall }
                    file_loaded 'Wall.rb'
                    I think I have to create a new entety for the faces theat are created to use it in push/pull ?
                      Okay. When it comes to a point and I cannot understand what it is then I move the whole topic to the developers' forum.
                      Good luck! πŸ˜‰
                      • sdmitchS Offline
                        sdmitch
                        http://rhin.crai.archi.fr/rld/plugin_details.php?id=250 is the link to midline2wall.rb which looks to be exactly what you want.
                        http://sdmitch.blogspot.com/
                          Thomas214
                          Hmmm yes but how can I select multiple lines?
                            Choose the Select tool.
                            Pick on an object [like a line].
                            Hold down Ctrl and pick on another object to add it to the selection.
                            Holding down Shift toggles an object in/out of the selection.
                            Holding down Shift+Ctrl and picking an object removes it from the selection.
                            With a face one click to pick face, two clicks to pick face and its edges and three clicks to select it AND all other edges and faces connected to it...
                              Thomas214
                              I was talking about the plugin πŸ˜„
                                Why not preselect the lines BEFORE running the tool? Then you process the selection??
                                You can pick kinds of objects with a Tool using pickhelpers and add them to a 'selection' etc BUT it's pretty complex for a simple tool... πŸ˜’
                                  Thomas214
                                  Can someone explain to me what this lines are for? I know they are for creating faces and offset lines but witch ones do what?
                                  width, height = results
                                  pts = tl[0].vertices
                                  i = 0
                                  pts2 = []
                                  pts.each do |pt|
                                  pts2[i] = pt.position + [0 , 0 , results[1]]
                                  i = i +1
                                  line_copy = entities.add_line pts2
                                  pts_copy = line_copy.vertices
                                  i = 0
                                  j = 0
                                  new_face = entities.add_face(pts[0], pts_copy[0], pts_copy[1], pts[1])
                                  new_face.pushpull (width / 2)
                                  if( not file_loaded?("zid.rb") )
                                  UI.menu("Plugins").add_item("Zid") { zid }
                                  file_loaded("zid.rb")
                                    Thomas
                                    You really need to learn to crawl before you walk...
                                    You expect 'random lines of code' to be interpreted for you !
                                    Please structure your questions a little more friendly...
                                    presumably this follows a UI.inputbox that results= ?
                                    There were two answers... width & height ??
                                    sets an array called 'pts' to be the vertices related to the first element in the array tl - as it's not named logically that couls be a list of faces OR edges...
                                    i = 0
                                    sets a reference called 'i' to be 0 [this is used later in the '.each do' loop ???
                                    pts2 = []
                                    Makes an empty array called 'pts2' - presumably this will be filled with elements later...
                                    pts.each do |pt| pts2[i] = pt.position + [0 , 0 , results[1]] i = i +1 end
                                    This process the vertices in 'pts' [it would've been better to call it 'verts' ??]
                                    And for each vertex [pt !!!] it returns its position as a 3d-point BUT swaps its z-value for whatever the results[1] was = probably the 'height' so why wasn't 'height' used ??
                                    Tis makes a line in [whatever] 'entities' [is] using the array 'pts2' as the 2 points - these have had their z values set to 'height'...
                                    This sets the array 'pts_copy' to be the vertices used by the edge 'line_copy' ???
                                    i = 0 j = 0
                                    sets the references 'i' and 'j' to 0
                                    This sets the reference 'new_face' to be the face [if any] that is made using the 4 points listed [if they are not coplanar it will fail!]
                                    It pushpulls the 'new_face' by half of the 'width [i.e. results[0] set earlier]
                                    Do NOT leave a gap between the 'pushpull' and its argument in parentheses [i.e face.pushpull(xxx) NEVER face.pushpull (xxx)]
                                    model.commit_operation end
                                    This closes the 'operation' and 'end's something - presumably the ' def zid' ?
                                    You must have a model.start_operation("MyTool") to 'close' it later...
                                    [ruby:1dtqmkst]if( not file_loaded?("zid.rb") )
                                    file_loaded("zid.rb")[/ruby:1dtqmkst]
                                    This makes the Plugins menu item a called '[ruby:1dtqmkst]Zid[/ruby:1dtqmkst]' which in turn runs the [ruby:1dtqmkst]def[/ruby:1dtqmkst] called '[ruby:1dtqmkst]zid[/ruby:1dtqmkst]' ???
                                    The [ruby:1dtqmkst]file_loaded[/ruby:1dtqmkst] parts need you to have a [ruby:1dtqmkst]require 'sketchup.rb'[/ruby:1dtqmkst] earlier and ensure that only one menu item appears even if you manually reload the script into the same SKP session...
                                    πŸ˜’
