    Ruby plugin?
    16 Posts 6 Posters 1.6k Views 6 Watching
    • T
      Thomas214
      @driven said:
      for something like this it's probably quicker and easier to draw [rectangle tool] the profile, select all lines and click followMe tool.
      there are lot of rubies that deal with more complex versions of this, but the standard tools can do quite a bit...
      [attachment=0:1tdufwpm]<!-- ia0 -->use_followMe.png<!-- ia0 -->[/attachment:1tdufwpm]
      This is somethin for my school project so to draw it this way it isn't an option πŸ˜„
        [attachment=0:3bwzyrmz]<!-- ia0 -->use_followMe.png<!-- ia0 -->[/attachment:3bwzyrmz]
        So write down the plan for your code...
        . check the model.selection contains some connected Edges (>>>path)
        . use a UI.inputbox() dialog to get the height
        . add a rectangle_face at start.position (p0) of first edge in path, calculating the other three points as p0=p1.clone; p1.z=p1.z+height etc using rectangle_face=entities.add_face(p0,p1,p2,p3)
        . use rectangle_face.followme(path) to extrude the new face along the path.
        . done
        • T
          Thomas214
          @tig said:
          [attachment=0:2kbtp9i4]<!-- ia0 -->use_followMe.png<!-- ia0 -->[/attachment:2kbtp9i4]
          . done
          Hmmm what if I useEdge.all_connectedthen the code from the the plugin push/pull face I have?
          • T
            Thomas214
            I got this far
            prompts = ["x:", "y:", "z:"]
            defaults = [10, 20, 100]
            input = UI.inputbox prompts, defaults, "Input data"
            x = input[0]
            y = imput[1]
            z = imput[2]
            model = Sketchup.active_model
            ent = model.entities
            sel = model.selection
            entities = model.active_entities
            pts = []
            pts[0] = [0, 0, 0]
            pts[1] = [x, 0, 0]
            pts[2] = [x, y, 0]
            pts[3] = [0, y, 0]
            Add the face to the entities in the model
            face = entities.add_face pts
            I just happen to know that the second and third entities in the
            entities objects are edges.
            entity1 = entities[1]
            entity2 = entities[2]
            edges = entity1.all_connected
            if (edges)
            UI.messagebox edges.to_s
            else
            UI.messagebox "Failure"
            faces = []
            sel.each do |e|
            	if e.is_a? Sketchup::Face
                     faces.push e
             Sketchup.active_model.start_operation "Wall"
            faces.each do |e|
                 ent.add_group e
                 e.pushpull (z)
            		Sketchup.active_model.commit_operation
            if( not file_loaded?('Wall.rb') )
            UI.menu('Plugins').add_item('wall') {wall }
            file_loaded 'Wall.rb'
            I think I have to create a new entety for the faces theat are created to use it in push/pull ?
            • GaieusG
              Okay. When it comes to a point and I cannot understand what it is then I move the whole topic to the developers' forum.
              Good luck! πŸ˜‰
              • sdmitchS
                sdmitch
                http://rhin.crai.archi.fr/rld/plugin_details.php?id=250 is the link to midline2wall.rb which looks to be exactly what you want.
                http://sdmitch.blogspot.com/
                • T
                  Thomas214
                  Hmmm yes but how can I select multiple lines?
                    Choose the Select tool.
                    Pick on an object [like a line].
                    Hold down Ctrl and pick on another object to add it to the selection.
                    Holding down Shift toggles an object in/out of the selection.
                    Holding down Shift+Ctrl and picking an object removes it from the selection.
                    With a face one click to pick face, two clicks to pick face and its edges and three clicks to select it AND all other edges and faces connected to it...
                    • T
                      Thomas214
                      I was talking about the plugin πŸ˜„
                        Why not preselect the lines BEFORE running the tool? Then you process the selection??
                        You can pick kinds of objects with a Tool using pickhelpers and add them to a 'selection' etc BUT it's pretty complex for a simple tool... πŸ˜’
                        • T
                          Thomas214
                          Can someone explain to me what this lines are for? I know they are for creating faces and offset lines but witch ones do what?
                          width, height = results
                          pts = tl[0].vertices
                          i = 0
                          pts2 = []
                          pts.each do |pt|
                          pts2[i] = pt.position + [0 , 0 , results[1]]
                          i = i +1
                          line_copy = entities.add_line pts2
                          pts_copy = line_copy.vertices
                          i = 0
                          j = 0
                          new_face = entities.add_face(pts[0], pts_copy[0], pts_copy[1], pts[1])
                          new_face.pushpull (width / 2)
                          if( not file_loaded?("zid.rb") )
                          UI.menu("Plugins").add_item("Zid") { zid }
                          file_loaded("zid.rb")
                            Thomas
                            You really need to learn to crawl before you walk...
                            You expect 'random lines of code' to be interpreted for you !
                            Please structure your questions a little more friendly...
                            presumably this follows a UI.inputbox that results= ?
                            There were two answers... width & height ??
                            sets an array called 'pts' to be the vertices related to the first element in the array tl - as it's not named logically that couls be a list of faces OR edges...
                            i = 0
                            sets a reference called 'i' to be 0 [this is used later in the '.each do' loop ???
                            pts2 = []
                            Makes an empty array called 'pts2' - presumably this will be filled with elements later...
                            pts.each do |pt| pts2[i] = pt.position + [0 , 0 , results[1]] i = i +1 end
                            This process the vertices in 'pts' [it would've been better to call it 'verts' ??]
                            And for each vertex [pt !!!] it returns its position as a 3d-point BUT swaps its z-value for whatever the results[1] was = probably the 'height' so why wasn't 'height' used ??
                            Tis makes a line in [whatever] 'entities' [is] using the array 'pts2' as the 2 points - these have had their z values set to 'height'...
                            This sets the array 'pts_copy' to be the vertices used by the edge 'line_copy' ???
                            i = 0 j = 0
                            sets the references 'i' and 'j' to 0
                            This sets the reference 'new_face' to be the face [if any] that is made using the 4 points listed [if they are not coplanar it will fail!]
                            It pushpulls the 'new_face' by half of the 'width [i.e. results[0] set earlier]
                            Do NOT leave a gap between the 'pushpull' and its argument in parentheses [i.e face.pushpull(xxx) NEVER face.pushpull (xxx)]
                            model.commit_operation end
                            This closes the 'operation' and 'end's something - presumably the ' def zid' ?
                            You must have a model.start_operation("MyTool") to 'close' it later...
                            [ruby:1dtqmkst]if( not file_loaded?("zid.rb") )
                            file_loaded("zid.rb")[/ruby:1dtqmkst]
                            This makes the Plugins menu item a called '[ruby:1dtqmkst]Zid[/ruby:1dtqmkst]' which in turn runs the [ruby:1dtqmkst]def[/ruby:1dtqmkst] called '[ruby:1dtqmkst]zid[/ruby:1dtqmkst]' ???
                            The [ruby:1dtqmkst]file_loaded[/ruby:1dtqmkst] parts need you to have a [ruby:1dtqmkst]require 'sketchup.rb'[/ruby:1dtqmkst] earlier and ensure that only one menu item appears even if you manually reload the script into the same SKP session...
                            πŸ˜’
