    [Plugin] Lines2Components v1.2
    6 Posts 6 Posters 8.8k Views 6 Watching
      I wrote a snippet for someone a while ago.
      To tidy up the Plugins Index here it is again.
      I have relinked the original posts back to here too...
      Here's the original thread http://forums.sketchucation.com/viewtopic.php?f=323&t=18198&p=147559#p147559
      It turns Selected Lines into Instances of a Selected Component...
      Usage:
      Put this file into 'Plugins' folder.
      Open a Model.
      Place Components and Lines...
      Select an Instance of the required Component, and
      at least one Line (Edge)***.
      Pick 'Lines2Components' from the 'Plugins' Menu.
      If the Selection doesn't contain Edges or an Instance
      an error dialog tells you...
      You are prompted for the 'Scaling': None/Z/XYZ.
      ***The Z-height (blue) of each Line relative to the Z-
      height of the required Component sets the 'Scaling'.
      One by one the Lines are turned into Instances of the
      required Component, Scaled to suit.
      Any Scaling is about the Instance's insertion point.
      The Instance's insertion point is taken to be the lower
      of the Line's ends.
      Unless the scaling is set to 'None' 'flat' Lines
      (equal Zs) are not used, then the insertion point is
      the Line's 'start'...[Lines2Components.rb](/uploads/imported_attachments/E9er_Lines2Components.rb) [![PayPalButton](//www.paypalobjects.com/en_US/i/btn/btn_donate_LG.gif)](https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=3675634)
        Missing the first 😳
        But maybe was not on board at this date 💚
        You are untiring! 😎
          boilingsnow
          Hi,TIG
          I discovered this plugin of yours today and think it's very useful for some circumstances.
          Now this tool can only turn vertical lines into components. Don't you think it would be more powerful if it can also change nonvertical lines (For example,the blue axes of the component along the lines) into components?
          • Arty2A Offline
            Arty2
            I was wondering, could this plugin be converted easily to take the length of a line then rotate and scale a component (along its z axis as boilingsnow noted) appropriately to it?
            • V Offline
              vandero
              this kind of plugin is workfull.
              • chialiang168C Offline
                chialiang168
                TIG:
                我來自台灣,姓名:星野傳說
                我不懂英文
                這是用google翻譯
                我利用Lines2Components V1.2改編
                發此源碼與大家分享
                I'm from Taiwan, name: Hoshino legend
                I do not know English
                This is a google translation
                I use Lines2Components V1.2 adaptation
                Send this source to share with you
                https://dl.dropboxusercontent.com/u/108539326/星野築網頁/004-應用教室/002-sketchup教室/插件應用/線組轉組件/google翻譯.JPG
                插件演示(Plug-in demo):
                https://dl.dropboxusercontent.com/u/108539326/星野築網頁/004-應用教室/002-sketchup教室/插件應用/線組轉組件/線組轉組件.gif
                An_Line_Group_to_ComponentInstance.rb
