    Dimensioning angles
    4 Posts 3 Posters 408 Views 3 Watching
      rdl001js
      I want to give an angle a dimension but i dont find how to do it. Can anywhone help me?
        There is no such native SU tool but there is a plugin:
        http://rhin.crai.archi.fr/rld/plugin_details.php?id=110
        It is not "dynamically" updating itself however (like normal dimensions do).
          rdl001js
          Thanks for quick response. I downloaded the tool and placed it in the plug in folder.
          But I did not yet found the tool in sketchup. Where should I find it?
            Look in the 'Tools' menu for 'Angular dimension'...
            Not every loaded script shows an entry under the 'Plugins' menu...
            You can often find in which menu a tool will appear by opening its .rb file in a plain text-editor [like Notepad.exe] and looking for the menu code, which is usually near the end of the text - it's usually clear where it shows and what it's called... That's what I just did to tell you where to look... πŸ˜‰
