Problem using print function within SU8pro
Hi All,
I am trying to print off from SU8pro a side of a building that must be 4" tall, and, 4" wide; two of them will be needed for this building, but, when i print it off using the print key within SU8pro, it gives me a side that measures only1" by 1.5"????, so need help please in finding out what im doing wrong........ Many thanks and regards to all, Tom............ :smile: -
Hard to tell exactly without seeing something. Could you post a screen shot? It could be a print set up issue or something to do with the way the model is organized or possibly the size/shape of the drawing window.
Since you have SU8 Pro, why not send the view to LayOut, set the scale there and make a PDF which you'll be able to easily print as needed.
Hi Thomas,
The current view matters when printing in SketchUp. If you are trying to print an elevation, select Camera > Parallel, and then either Front, Left, Right, or Back views before opening the Print dialog.
You can then adjust the Page Size and Scale of the output in the Print Dialog.
Register LoginAdvertisement
