    [Plugin] Pen Tool +
    126 Posts 40 Posters 109.7k Views 40 Watching
      There is v1.7.0 updated in the PluginStore http://sketchucation.com/pluginstore?pln=Pen_Tools I've updated it for Rich - it now avoids the errors causing the first point to auto-create and to always be at the origin, and also some of the tools [like soft/weld] to be messed up completely...
      If you get issues with tools like this, then it's always useful to try them with the Ruby Console open and pass on any errors.
      In the case of these 'Pen Tools' there were clear error-messages relating to the string translations, which worked with earlier versions of SketchUp if the 'example,rb' tools had also been setup, but which now no longer work with newer SUp versions, and Ruby2 is not as forgiving either !
      It was a simple fix to edit the file and delete the 21 erroneous 'langhandler' calls highlighted in the error-messages...
      I think it now works fine - please test and report if I'm wrong !
      • Clayton49C Offline
        Clayton49
        To all,
        I was looking for a tool to just draw dashed lines, this tool seems to suggest it can do this o.k. therefore does it work with SU-PRO-2017 ? Or is there another tool that can draw dashed lines or various line styles similar to plain 2D-CAD ?
        I seem to remember a set of tools that just functioned like 2D-CAD, but unsure if it had line style options ?
        Anyway a tool like this would be quite useful to add further detail to extracted sectional model views for floor plans etc, as not everything needs to be modeled in 3D-SU. 2D items like: plan doors swings, plaster lines & symbols to name a few.
        Over & out,
        CJT54
        Over & out,
        Clayton.
        %(#008000)[Trotman & Taylor
        Architectural Consultants]
          There is a tool for drawing guides that you might use as dashed lines but remember, they will be deleted if you hit Delete Guides.
          TIG's 2D Tools has a tool that can draw "styled" lines. You might check that out.
            Clayton49
            [attachment=0:otl9wsk6]<!-- ia0 -->Screenshot - 7_30_2017 , 2_26_47 PM.png<!-- ia0 -->[/attachment:otl9wsk6]
            Hi Dave-R,
            Yes, the TIG'S-2D-TOOLS is what I'm after, but see it's not SU-PRO-2017 validated... grrr...I'll have to post something on that on the forum to see if it's o.k. to use.
            Thanks,
            Over & out,
            CJT54
            Over & out,
            Clayton.
              It's fine to use.
              Just set your restriction policy in the extension manager to not be over zealous.
                It works just fine with SketchUp 2017. The fact that it shows as "unsigned" doesn't mean it won't work.
                • 6
                • 7
                • 7 / 7
