    Chesterfield sofa
    5 Posts 3 Posters 1.1k Views 3 Watching
      rasa
      Hey,
      Anyone know how to get the buttons in a Chesterfield sofa, with free plugins? is there a tutorial out there? Please help.
      • numbthumbN Offline
        numbthumb
        Something like this: http://forums.sketchucation.com/viewtopic.php?f=335&t=34736 ?
        No buttons however, but adding them would be the easy part 😄
        Note that SDS ( now Artisan ) is not free, but it´s worth buying in any case.
        A limited, although free version of a subdivision plugin for Google SketchUp can be found here: http://www.smustard.com/script/Subdivide
        Comfortably numb...
          rasa
          Thank you numbthumb, I can't believe how easy it is.
          • N Offline
            nytrerter Newcomers
            HI,
            Numthumb has described it very simply as "how to get the buttons in a Chesterfield sofa".
            • N Offline
              nytrerter Newcomers
              You can replace a button on a chesterfield sofa by removing the old button-through pulling. Discard it and make a knot of twine on a metal pin. Adjust it on the twine needle and insert it into the sofa. Rotate counterclockwise and remove the twine needle. Install the new button and make knots.
