    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Engraving a Ring
    12 Posts 4 Posters 1.2k Views 4 Watching
      detezvezda
      Hi, friends
      I have a litle problem. I need to engrave a ring, but I dont have proper skill apparently. Source is a DWG file taken from Corel. Actually (CDR - WMF - DWG). I trying Drape, but with no luck. Intersection and solid tools does not work as well...
      Any idea...
      http://s1.postimage.org/1335cil1g/000.jpg
        Have you scaled the model up? SU has problems working with small (less than 1mm) geometry.
          detezvezda
          Diameter of the ring is 26.4 cm. It is 1:10...
            Scale the ring up by 10 then if the solid tools/drape works you scale back down 0.1
              d12dozr
              Welcome to the forum, DeteZvezda!
              It may work better to engrave first on flat profile of the ring, then bend the ring into an arc using Shape Bender. One limitation of Shape bender is it cannot bend into a complete circle, so you'll have to do it in two steps. I have done an example for you, see below...
              Ring test.skp
              http://goo.gl/f7ooYh
                detezvezda
                Thanks d12dozr, I tray it, and it work pretty well. However, it has a aproblem to stay solid, and joint push/pull is not the best on a complex surfaces. But I am not giveing up ... πŸ˜„
                  d12dozr
                  Yes, complex surfaces are difficult to keep solid...lucky for us, Thomthom made a solution: Solid Inspector And of course, make sure you are modeling at a larger-than-life scale like Rich suggested above πŸ˜„
                  Are you 3D printing the ring?
                    detezvezda
                    I did it.
                    http://s3.postimage.org/1sxz6y0jo/001.jpg
                    http://s3.postimage.org/1sy0uhd1g/002.jpg
                    1. Shape Bender
                    2. Healing to solid
                    3. Intersect
                    4. Welding and intersecting
                    5. Joint push/pull
                    On a 13584.926408x13584.926408 cm it stayd solid... 😎
                      Deborah?
                        d12dozr
                        Good job, I hope you'll post pictures if you get made for real!
                          detezvezda
                          β˜€
                          http://s2.postimage.org/9a02bl5w/002.jpg
                          http://s2.postimage.org/9a8c0bms/003.jpg
                            d12dozr
                            Nice renders πŸ‘ β˜€
