    Bug with TAB character in menu (SU8)
    10 Posts 5 Posters 871 Views 5 Watching
    • fredo6F Offline
      fredo6
      Did anyone notice that in SU8, the TAB Character (\t) seems to be ignored or treated as an end of String?
      This happens in the contextual menus of some of my plugins for displaying equivalent functions keys.
      It does work fine in SU6 and SU7 however
      Fredo
        Never noticed it - but I've never thought of using tab characters in menu texts...
          I've always avoided non-standard characters in menu-text - e.g. '&' is a no-no too...
            True - it's usually a special character used to indicate what is the activating key.
            • fredo6F Offline
              fredo6
              The Tab allows to justify text on the right (in my case, it is the short cuts). This is relatively standard in Windows. Sketchup itself uses this to shoz the short cuts in the main menu bar
              The problem is that it does work in SU6 and SU7 but not in SU8.
              Maybe I should log the bug to the Beta forum.
              Fredo
                AlexMozg
                Fredo6
                I noticed this a long time.
                See my topic (item 2):
                http://forums.sketchucation.com/viewtopic.php?f=180&t=30583
                • fredo6F Offline
                  fredo6
                  @alexmozg said:
                  Fredo6
                  Alex,
                  Thanks. In understand these little things are irritating.
                  Did you log a bug to the SU Site or should I do it?
                  Fredo
                  • Dan RathbunD Offline
                    Dan Rathbun
                    It's locked now.
                    You have to use the contact webform:
                    http://sketchup.google.com/support/bin/request.py?contact_type=bug
                    I'm not here much anymore.
                      Dan Rathbun
                      FYI:
                      [MSDN : About Menus : Menu Shortcut Keys](http://msdn.microsoft.com/en-us/library/ms647553(v)
                        AlexMozg
                        Fredo
                        You can do it, because I don't know how to do it.
