    Curved, ramped feature wall
    4 Posts 3 Posters 493 Views 3 Watching
    • D
      dorfpunk
      Well, I'm trying to model a garden that I have been working on. It contains as its main feature a large curved feature wall, that as well as curving ramps up from 500mm high to 1100mm at its highest point. I have drawn some wires to explain what I meanWall.jpgWall 2.jpg
      they are not perfect but they give an idea. I have two problems
      1: How do I create a wall that follows this path. I have tried a few different things but nothing that is particularly satisfactory
      2: Then, how do I give it a material? It will be a face brick structure made of truly beautiful dark brown/blue bricks with a dark oxide mortar - as I said a major feature. So assuming I can build the thing, how would I add a material in a way that will be smooth and look good?
      I am sure there are simple answers to both these but rather than beat my head against this particular wall for the rest of the day I figured I would ask the community.
      it's a beautiful night - you can almost see the stars
      • jeff hammondJ
        jeff hammond
        you can use shapeBender:
        http://forums.sketchucation.com/viewtopic.php?t=18210
        click pic for larger
        i'm not quite sure what your texture looks like but this wall can be done fairly decently with the standard brush tool's functions.
        dotdotdot
        • D
          dorfpunk
          Yep - that'll work. Thanks. That's what happens when I accidentally miss such an important plugin.
          • pbacotP
            I like this tutorial by Earthmover... I guess you could tell by my posts there. 😳
            http://forums.sketchucation.com/viewtopic.php?f=18&t=14565&p=110238&hilit=curved+wing+wall#p110238
