    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 429.3k Views 172 Watching
      smooge
      sorry no that is from maxwell i think!
        craigcampbell66
        Some help with Sketchup Ivy appreciated. I have downloaded/installed and run the plugin fine although there was an error message at installation and each time I start the plugin(capture). My issues are that The leaf 2 and 3 have a white background displayed in model and when rendered. see image capture1. The material editor in Sk8 has leaf 1 as a .tif and 2 and 3 as .jpg's. I thought I could just go into the folder in plugins find the images and convert them to tifs to give a see through background but therein lies my problem. I can't find the plugin or folder where I extracted it to nor in any of the sub folders of sketchup. I have tried to reinstall (both extract to and copy from a separate location) but it says the file is already there and would I like to overwrite it?? Given I can't find it I can't remove it to try and re-install again in case the initial was corrupted ie the white backgrounds. Thanks to Pierre though for what looks like a great plugin once I get it sorted.
        Thanks also to whoever is able to assist
        • G Offline
          gilles63
          it works actually quite well for me, at least on windows . A few things are a bit mind boggling , like for example why it generate ghost leaves components that appears in textures and components editors, but once you replace the awfull leaves in the folder textures with decent ivy leaves components ( be sure to give them the same name, ivyleaf_1 etc, it looks as good as the original plugin . More, you can always reload the components with others to create climbing roses, bougainvillea etc . I ll post some of my components tomorrow .
          • G Offline
            gilles63
            • G Offline
              gilles63
              ok, here are new more realistic ivy leaves and components for a climbing rose . Just delete everything in the plugin's texture folder except the branch texture and replace them with the ivy leaves components you ll find in the Zip file ( ivyleaf_1 . 2 . 3 ) et voilà , you can now grow your ivy . If you want to make a climbing rose, grow an ivy then reload the ivy leaves with the roses components contained in the zip file
              ivy textures.zip
              • OxerO Offline
                Oxer
                Thanks, very useful!! 👍
                [http://www.oxervision.blogspot.com/(http://www.oxervision.blogspot.com/)]
                • G Offline
                  gilles63
                  you are welcome , and myself i must thank Pierre for a great plugin . This textures can be improved, especially the roses, and i realise that some axis should be changed, the leaves tend to hang in the same direction, but i ll work on it and post a better version in the next days .
                  • G Offline
                    gilles63
                    like promised, i worked on the components . My apologies by the way, i realised that the leaves components for the roses was seriously so underscaled that it became invisible . Anyway, here is a better one with a 3d flower and components to create a bougainvillea . I think it looks quite good . My advice would be to manually edit the model by removing blooms or leaves where necessary . Besides, the model can be quite heavy, lets say around 5 Mb for an average climbing rose .
                    textures for ivy generator.zip
                    • G Offline
                      gilles63
                      quick render
                      • G Offline
                        gilles63
                        climbing rose
                        • charly2008C Offline
                          charly2008
                          Very nicely done, I like it very well.
                          Charly
                          • G Offline
                            gilles63
                            thanks, but all credit must go to Pierre . It was easy to improve on it .
                              tedvitale
                              I am really looking forward to playing with this one!
                              Ted Vitale
                              3D Artist and designer
                              Sketchup 2013 Pro
                                lamandrion
                                very nice gilles63!
                                Requesting wisteria sinensis 😉
                                http://www.fassadengruen.de/uploads/pics/Wisteria_Detail_240.jpg
                                • Y Offline
                                  yudii
                                  Hello.. i am new for vray sketchup. but i found something (like i attached). the render result that leaf had white colour on the edge. any think i can do to remove the white color?
                                  btw this is very interesting plugins..
                                  regards
                                  this is the render result.
                                    Yudii
                                    Look back through this thread and you'll find some posts where others have posted alternative versions of the 'images' used by the tool so that there are no edges, backgrounds etc...
                                      regards
                                      In the Diffuse layer of the leaf materials, ensure you've enabled the "Use texture transparency" checkbox. (Might be different wording - but it's the jist of it.)
                                      • JVT_LTDJ Offline
                                        JVT_LTD
                                        Many thanks... very nice update...
                                        • JVT_LTDJ Offline
                                          JVT_LTD
                                          @gilles63
                                          Could you kindly share your parameter for the above sample of yours its truly amazing you could made that output so realistic... If its O.K. to you, thanks in advance...
                                            mvdv
                                            If anyone knows how to fix the Ivy plugin for Mac, a great number of people will be very thankful, as will I.
                                            My problem is, I see the dialog box, can change the parameters, but when I start clicking on a surface -> nothing happens. I can keep on clicking it, there will never be a red line. I also tried it on windows where it works just fine. There is also nothing happening in the ruby console.
                                            Can anyone help me out?
                                            Thanks,
                                            Michael
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 36
                                            • 37
                                            • 23 / 37
