    Can sketch up be imported to alias?
    6 Posts 6 Posters 1.7k Views 6 Watching
      Ands43
      As per the subject. thanks
      • Jean LemireJ Offline
        Jean Lemire
        Hi Tails, hi folks.
        I don't know the Alias software. Can you give more details like the URL of the web site or the file formats used or suported by Alias ?
        Just ideas.
          ledisnomad
          I assume you mean Maya, formerly owned by Alias, currently owned by Autodesk. If so, you can export your SketchUp model as an FBX, OBJ, or DXF and import it into Maya. I don't have Maya currently, so I can't test it. I'd try them in the order I listed them since FBX is Autodesk's prefered file format for interoperability these days. Then OBJ is a nice almost-universal format that should take most of the info from your SU model. DXF is the least robust. Hope that helps.
          • mitcorbM Offline
            mitcorb
            I thought Alias had closed down. I know Alias Sketchbook was bought by Autodesk. I still have a copy of Alias Sketchbook on my tabletpc and I never updated/upgraded.
              dedmin
              NURBS modeling - like Rhino. Exchange with SketchUP via .dxf or .fbx
              http://images.autodesk.com/adsk/files/alias_detail_brochure_us_english.pdf
              • numbthumbN Offline
                numbthumb
                Autodesk Alias?
                It can import .obj files as far as I can remember.
                Comfortably numb...
