    Arched Brick Surrounds
    16 Posts 6 Posters 3.4k Views 6 Watching
    • leedeeteeL Offline
      leedeetee
      Hiya chaps,
      I've never thought about this problem before, but am now faced with having to model an arched brick lintel/surround, similar to the one below.
      http://farm6.static.flickr.com/5081/5243323883_feec0fd9bc.jpg
      Is there an easy way to create the above effect with standard textures?
      Very interested to know ...
      Thanks!
        I think this would be a case where I would draw the bricks with individual faces and add material to each of them. If there were a number of them, I would draw one of them and add the materials. I would then export an image of it which could then be imported as a material to apply to all of them.
          d12dozr
          Gai has a tutorial here using Thomthom's UV Toolkit: http://forums.sketchucation.com/viewtopic.php?p=299717#p299717 ...might be a little faster than individual mapping πŸ˜‰
          http://goo.gl/f7ooYh
            leedeetee
            Works brilliantly, thank you.
            And thanks to Gai for a great tut (although could maybe do with explicit instructions in post #1 for smoothing the subdivisions?).
              Added:
              @gaieus said:
              Best is to soften these dividing edges (for the convenience of the next step)
              πŸ˜‰
              • Alan FraserA Offline
                Alan Fraser
                I guess if you did a lot of this kind of thing...either because you design a lot of haciendas or have an inexplicable fascination with the Romanesque πŸ˜‰ you could follow Gai's advice, but then do a SU render and prefabricate a load of custom arch maps in all the most common sizes...which would not only save quite a bit of time overall, but probably quite a lot of geometry as the whole exterior of the arch would then be just a single face. The original soldier course is for underneath, in case you have an open archway.
                3D Figures
                  πŸ‘
                  Deinitely a good way to go - I also did this when I was modelling these arches (especially that when projected, they could be used on arched windows curved on an apse wall)
                  https://lh5.googleusercontent.com/_zcvsIuYiVbo/Suw3FoVmC8I/AAAAAAAACu4/pZfgc8630Gg/Bazilika-Texture20.jpg
                  Maybe the arches became a bit too uniform there (I later made a better, modified version though) but say with two texture maps and flipping the arch once in a while, you can get quite a good randomness.
                  • pbacotP Offline
                    @alan fraser said:
                    you could follow Gai's advice, but then do a SU render and prefabricate a load of custom arch maps in all the most common sizes....
                    This sounds like an interesting approach for other uses. What is a SU render?
                    Great help Gai. Learning this sort of thing leads to better approaches to problem solving in SU in general (Of course, the next trick would be to make the mortar joints expand and the bricks stay rectangular.)
                    Thanks, Peter
                      Alan Fraser
                      Peter, I meant just flip the model onto its back, go to plan view and export a jpg....or you could probably do the same from the front elevation if you switch shadows off.
                      3D Figures
                        Certainly. The above example was my very first attempt to do this with TT's UV Toolkit beforeit could do the "remember/restore UV" trick.
                          leedeetee
                          Just thinking ....
                          Does this work in conjunction with the textures associated bump map, too??
                            Yes.
                            • pbacotP Offline
                              Oh, I thought it was using that. So there's a way to do rectangular bricks that is as easy?
                                leedeetee
                                @gaieus said:
                                Yes.
                                Awesoooooooooome. πŸ‘
                                  Something like this?
                                  Rendered with Twilight
                                  Bump map and Twilight setup included
                                    Alan Fraser
                                    πŸ˜„
                                    3D Figures
