    Help With Banked Curve
    4 Posts 2 Posters 823 Views 2 Watching
    • C
      cmartin
      I know how to make a bank curve using the follow me tool. But I can't flatten the bank curve back out when its finished.
      I've attached my sketchup file. It has the bank curve, but the sides are not connected because I don't know how to make the curve go from being turned sideways to going flat.
      banked curve.skp
      • TIGT
        You need to make the profile[s] and top/bottom rails as complex curves [weld...] and then use a tool like my EEbyRails or Fredo's CurviLoft to make the swept mesh........
        PS: your sweep must meet the straight parts 'tangentially' [square], otherwise you'll always get a noticeable crease at the join...
        • C
          cmartin
          Unfortunately, I don't understand alot of the terminology you used.
          When you say weld, what do you mean?
          Also, what is a swept mesh?
          Sorry for the confusion, I'm just still an infant at this.
          • TIGT
            There is a free tool called weld.rb available at Smustard.com
            It lets you selected connected edges and weld them into a 'curve'.
            Arc etc are already curves BUT this lets you combine arcs and other lines into a single 'curve'.
            Most of the EEby... tools need you to select 'curves'.
            Even if you want one straight side you need to Divide that edge into 2 or more pieces and then make a curve of its parts using weld.
            A 'swept mesh' is what you get when you use a tool like EEbyRails - the faceted surface the mesh, and it sweep along the rails...
