    [Plugin] CameraKeyMaker 1.0 (Update 2011-04-09)
    118 Posts 53 Posters 155.3k Views 54 Watching
      macgile
      This plugin generates smooth animations based on a camera path (bezier spline). Camera keys are editable and saved within the drawing.
      How to install:
      First install Google Bezier: https://sketchucation.com/pluginstore?pln=bezier
      Second install CameraKeyMaker: https://sketchucation.com/pluginstore?pln=CameraKeyMaker
      Restart SketchUp
      Shortcuts:
      Alt + Q : Add camera key / Update position of key (first press down. see below)
      Down: Edit current key.
      Left: Previous key.
      Right: Next key.
      Up: Preview animation.
      Enter: Generate Scenes (pages)
      Edit camera key mode is available only (top - right - left - front ) view.
      Soon:
      I want to add an effect to mimic the pitch of the airplane flight.
      Known Issues:
      1. WARNING ! when you want generate .avi file it can crash sketchup (desactivate tool first "click on select tool" )
      require bezier.rb
      Update 2011-04-09 (Fixed various errors with large model)
      Direct download : https://sketchucation.com/pluginstore?pln=CameraKeyMaker
      Tutorial basic:
      Demo animation :
      Cloister galleries Thoronet (test advanced animation)
      Enjoy!
      • srxS Offline
        srx
        Great! Thank you!
        www.saurus.rs
        • KrisidiousK Offline
          Krisidious
          nice animation. could you describe what makes your animation plugin different from others?
          By: Kristoff Rand
          • PixeroP Offline
            Pixero
            Wow! I'm stunned. 😲
            This is exactly what I always wanted for SU animation.
            Thank you soooo much!
            Did I say Wow?
            • PixeroP Offline
              Pixero
              Just did a quick test and it's supersmooth.
              Love it already.
                Yes, apparently very nice, smooth animations. 👍 👍 👍
                I wonder how they can be "translated" into 3rd party renderers' camera exporters (this is obviously not your task but of those who write them - hopefully it is feasible).
                  macgile
                  Love it already.
                  Thank you very much Pixero 😄
                    Excellent idea.
                    My only suggestion is that you put it in the 'Camera' menu rather than the 'Plugins' [I've already edited my version...] 😄
                      macgile
                      Yes it's possible.
                      I know that in LightWave the camera paths are stored in envelopes it's just a spline.
                        macgile
                        @tig said:
                        Excellent idea.
                        Of course it's obvious 😄
                        Thank's TIG
                        best regard.
                        • jarynzlesaJ Offline
                          jarynzlesa
                          nice and smooth 👍 .
                          http://www.vizualizaceschodiste.mypage.cz/
                            dbalex
                            It's a great plugin! I'm testing it right now but I'm trying to edit the path (in top or front view in parallel and perspective) and I can't select and move the points.. Does anyone else have this problem? I'm using sketchup 8 on windows 7
                            http://www.bocostudio.com
                              macgile
                              Thank's for your reply dbalex !
                              Strange thing!
                              Check your keyboard shortcuts if it already occupied by another tool (see above in the header of this post to shortcuts)
                              Check if you have groups or layers in your model.
                              sometimes when a key is published in conjunction with a group is selected that is problematic.
                                dbalex
                                Is there a shortcut key for editing the points? because I can update the keyframes by putting the camera in the right spot and update the keyframe, but I can't select them and move them in the orthographic views.. non of the shortcut your plugin uses is used in my shortcuts so I don't think that's the problem, anyway even like this it's a great tool! thanks for the fast reply
                                  dbalex
                                  and I have no groups or layers in the scene, just a testscene with a simple cube.
                                    macgile
                                    Sorry for the inconvenience.
                                    Check if you have the file bezier.rb
                                    The plugin has been tested on Sketchup v.7 and v.8 (pro or not)
                                    best regard
                                      dbalex
                                      yes I thought of that also so I installed bezier.rb again with no results.. will try it on my other computer when I have time and will let you know if it works on that one. Thanks!
                                      • mitcorbM Offline
                                        mitcorb
                                        Would some other Bezier plugin work with this tool? If not, could this be causing the difficulty?
                                          macgile
                                          thank's mitCorb for reply 😄
                                          In the next major update (1.2) the file "bezier.rb" will no be required.
                                          • urgenU Offline
                                            urgen
                                            ....o-o-o-excellent! 👍
                                            --pupil forever...------
                                            • 6
                                            • 1 / 6
