    [Plugin] CameraKeyMaker 1.0 (Update 2011-04-09)
    118 Posts 53 Posters 158.8k Views 54 Watching
    • PixeroP
      Pixero
      Just did a quick test and it's supersmooth.
      Love it already.
      • GaieusG
        Yes, apparently very nice, smooth animations. 👍 👍 👍
        I wonder how they can be "translated" into 3rd party renderers' camera exporters (this is obviously not your task but of those who write them - hopefully it is feasible).
          macgile
          Love it already.
          Thank you very much Pixero 😄
            Excellent idea.
            My only suggestion is that you put it in the 'Camera' menu rather than the 'Plugins' [I've already edited my version...] 😄
              macgile
              Yes it's possible.
              I know that in LightWave the camera paths are stored in envelopes it's just a spline.
                macgile
                @tig said:
                Excellent idea.
                Of course it's obvious 😄
                Thank's TIG
                best regard.
                • jarynzlesaJ
                  jarynzlesa
                  nice and smooth 👍 .
                  http://www.vizualizaceschodiste.mypage.cz/
                    dbalex
                    It's a great plugin! I'm testing it right now but I'm trying to edit the path (in top or front view in parallel and perspective) and I can't select and move the points.. Does anyone else have this problem? I'm using sketchup 8 on windows 7
                    http://www.bocostudio.com
                      macgile
                      Thank's for your reply dbalex !
                      Strange thing!
                      Check your keyboard shortcuts if it already occupied by another tool (see above in the header of this post to shortcuts)
                      Check if you have groups or layers in your model.
                      sometimes when a key is published in conjunction with a group is selected that is problematic.
                        dbalex
                        Is there a shortcut key for editing the points? because I can update the keyframes by putting the camera in the right spot and update the keyframe, but I can't select them and move them in the orthographic views.. non of the shortcut your plugin uses is used in my shortcuts so I don't think that's the problem, anyway even like this it's a great tool! thanks for the fast reply
                          dbalex
                          and I have no groups or layers in the scene, just a testscene with a simple cube.
                            macgile
                            Sorry for the inconvenience.
                            Check if you have the file bezier.rb
                            The plugin has been tested on Sketchup v.7 and v.8 (pro or not)
                            best regard
                              dbalex
                              yes I thought of that also so I installed bezier.rb again with no results.. will try it on my other computer when I have time and will let you know if it works on that one. Thanks!
                              • mitcorbM
                                mitcorb
                                Would some other Bezier plugin work with this tool? If not, could this be causing the difficulty?
                                  macgile
                                  thank's mitCorb for reply 😄
                                  In the next major update (1.2) the file "bezier.rb" will no be required.
                                  • urgenU
                                    urgen
                                    ....o-o-o-excellent! 👍
                                    --pupil forever...------
                                    • OxerO
                                      Oxer
                                      Thanks for the plugin, it's very useful but i work on Mac, the plugin runs but there are problems:
                                      1. On Mac the keys combination (Alt+Q, ...) and the arrow keys don't works so you can't create the Camera Keys.
                                      2. The path to camera_path.html file is invalid and the file don't open when you push Enter key.
                                        Only the first time that i ran the plugin i could create the camera keys (Ctrl+Q on Mac) but the next times no and when i pushed the Enter key this were the Console message:
                                      Console error message
                                      I have translating the plugin to spanish language, when i finished it i'll upload it here.
                                      Bye and i hope your help for fix these problems.
                                        Using keys that might be mapped by others to do stuff [I already use Alt+Q to orient-faces] is a bad idea... use just modifiers like Alt or Cmd or Shift etc that can't be used as shortcuts otherwise...
                                          macgile
                                          @oxer said:
                                          [attachment=0:2pn7yb90]<!-- ia0 -->Captura de pantalla 2011-04-13 a las 04.12.36.JPG<!-- ia0 -->[/attachment:2pn7yb90]
                                          Thanks for reply Oxy
                                          Sorry for Mac users.
                                          I'll fix these bugs soon and contact you.
                                            macgile
                                            Thank you for your reply TIG
                                            Yes I do not know why I picked the keys complicated.
                                            • 1 / 6
