    [Plugin] CameraKeyMaker 1.0 (Update 2011-04-09)
    118 Posts 53 Posters 158.8k Views 54 Watching
      macgile
      @tig said:
      Excellent idea.
      My only suggestion is that you put it in the 'Camera' menu rather than the 'Plugins' [I've already edited my version...] 😄
      Of course it's obvious 😄
      Thank's TIG
      best regard.
      • jarynzlesaJ
        jarynzlesa
        nice and smooth 👍 .
        http://www.vizualizaceschodiste.mypage.cz/
          dbalex
          It's a great plugin! I'm testing it right now but I'm trying to edit the path (in top or front view in parallel and perspective) and I can't select and move the points.. Does anyone else have this problem? I'm using sketchup 8 on windows 7
          http://www.bocostudio.com
            macgile
            Thank's for your reply dbalex !
            Strange thing!
            Check your keyboard shortcuts if it already occupied by another tool (see above in the header of this post to shortcuts)
            Check if you have groups or layers in your model.
            sometimes when a key is published in conjunction with a group is selected that is problematic.
              dbalex
              Is there a shortcut key for editing the points? because I can update the keyframes by putting the camera in the right spot and update the keyframe, but I can't select them and move them in the orthographic views.. non of the shortcut your plugin uses is used in my shortcuts so I don't think that's the problem, anyway even like this it's a great tool! thanks for the fast reply
                dbalex
                and I have no groups or layers in the scene, just a testscene with a simple cube.
                  macgile
                  Sorry for the inconvenience.
                  Check if you have the file bezier.rb
                  The plugin has been tested on Sketchup v.7 and v.8 (pro or not)
                  best regard
                    dbalex
                    yes I thought of that also so I installed bezier.rb again with no results.. will try it on my other computer when I have time and will let you know if it works on that one. Thanks!
                    • mitcorbM
                      mitcorb
                      Would some other Bezier plugin work with this tool? If not, could this be causing the difficulty?
                        macgile
                        thank's mitCorb for reply 😄
                        In the next major update (1.2) the file "bezier.rb" will no be required.
                        • urgenU
                          urgen
                          ....o-o-o-excellent! 👍
                          --pupil forever...------
                          • OxerO
                            Oxer
                            Thanks for the plugin, it's very useful but i work on Mac, the plugin runs but there are problems:
                            1. On Mac the keys combination (Alt+Q, ...) and the arrow keys don't works so you can't create the Camera Keys.
                            2. The path to camera_path.html file is invalid and the file don't open when you push Enter key.
                              Only the first time that i ran the plugin i could create the camera keys (Ctrl+Q on Mac) but the next times no and when i pushed the Enter key this were the Console message:
                            Console error message
                            I have translating the plugin to spanish language, when i finished it i'll upload it here.
                            Bye and i hope your help for fix these problems.
                              Using keys that might be mapped by others to do stuff [I already use Alt+Q to orient-faces] is a bad idea... use just modifiers like Alt or Cmd or Shift etc that can't be used as shortcuts otherwise...
                                macgile
                                @oxer said:
                                [attachment=0:2pn7yb90]<!-- ia0 -->Captura de pantalla 2011-04-13 a las 04.12.36.JPG<!-- ia0 -->[/attachment:2pn7yb90]
                                Thanks for reply Oxy
                                Sorry for Mac users.
                                I'll fix these bugs soon and contact you.
                                  macgile
                                  Thank you for your reply TIG
                                  Yes I do not know why I picked the keys complicated.
                                  • T
                                    Tiggz1
                                    Awesome feature - Thankyou!!
                                    One question - forgive me if I missed it. How do I delete the Camera Key path so I can start from scratch?
                                    • E
                                      Ecuadorian
                                      This looks like exactly what I need to smooth out the motion in my LightUp animations.
                                      Thank you! 😛
                                      -Miguel Lescano
                                        macgile
                                        Thank for reply Tiggz1 😄
                                        just delete path in background layers.
                                        best regard 😄
                                        • W
                                          wwwyoose
                                          hi
                                          I am trying this plugin and it dont work whit the short cut. alt+q.
                                          I have mac are ther some diffrent short cut?
                                          Best Achim
                                            macgile
                                            @wwwyoose said:
                                            hi
                                            Best Achim
                                            Thank's wwwyoose 😄
                                            This bug is fixed in the next version with many other improvements
                                            comming soon!
                                            best regard
                                            • 1 / 6
