    Applying aerial to topo
    7 Posts 5 Posters 1.2k Views 5 Watching
    • P
      PTocco
      Hi, I'm running Sketchup Pro 8 WinXP and would like to paste an aerial image onto a topographic surface. I created the contours in Autocad then imported to SU and had no trouble creating the surface witht the Sandbox tool. But when I apply the aerial jpg, it fragments into many "splinters", each oriented differently. I know I've seen it done where an image is mapped to a contoured surface but I don't remember it. I have searched but havn't found the answer yet. I tried Alt-clicking the texture and selecting "projected" but that didn't help. Does anybody know the correct procedure?
      • P
        PTocco
        I figured it out. I just didn't apply "projected texture" properly. I applied the aerial map to a large flat surfce and placed it right above the topo surface. Then I right clicked the flat textured surface and selected Projected. Then I alt-clicked the Paint Bucket onto the flat surface, it becomes an eye dropper, then I apply that to the topo surface and voila.
        • GaieusG
          First of all, draw a big rectangle (or any kind of shape your terrain is) exactly above the terrain. Import the image, position it on this face accurately then right click > texture > Projected...
          Now sample this projected image with the Alt+ tool (it will turn into an eyedropper) and paint the surface of your terrain (if it is a group, edit it to access the raw geometry inside as projected material will not work on groups).
          Finally delete the rectangle.
          • GaieusG
            Speaking of cross posting...
            πŸ˜„
            • M
              mozzie
              There're a couple of useful videos that demonstrate painting onto a topo at "Go 2 School".
              For the eyedropper ...
              http://www.go-2-school.com/media/view/37
              and for a tiling technique
              http://www.go-2-school.com/media/view/1
              The videos are specifically for projecting colour images onto GE terrain in SU6 & 7, but the methods work for what you want to do.
              • H
                Hearbirds
                Yes! thank you G, no one ever mentioned that 😍
                • panixiaP
                  panixia
                  usually fredo's topo shaper + trhu paint (quad mapping metod) lead to better results. i strongly suggest to give it a try.. πŸ‘
