    Ruby Console
    4 Posts 3 Posters 368 Views 3 Watching
    • G Offline
      greg24k
      I am not sure where to post this I am new here, but I have a question about ruby console...For some reason in my windows tab in Sketchup 8 I have 3 Ruby Console's tabs. How can I remove the 2?
        Hi Greg,
        I remember having the same issue in the past. It was some plugin(s?) that caused it. Try to remove all your custom plugins (that you installed) and move them back one by one (or move half of them back than half of the rest again) until you see which one causes it.
        It doesn't do any harm though so if there is no fix, still no problem.
        • G Offline
          greg24k
          @gaieus said:
          Hi Greg,
          Thank you Gaieus, I will try doing that. πŸ‘
            Rather than move them back one by one you can half, and half again until you find it. E.G. Make two temporary folders Disabled and Safe. Put half of your scripts in Disabled, leave half in Plugins - if the error still happens you know which half in safe - move the contents of Disabled into Safe. Now repeat moving half of what's in Plugins into Disabled - this time lets assume the error has gone, therefore move the contents of Plugins into Safe and half of the contents of Disabled into Plugins.... repeat swapping things like that until you have the culprit file[s] and tell us what they are !! Doing if by halves is much quicker; 512 >> 256 >> 128 >> 64 >> 32 >> 16 >> 8 >> 4 >> 2 >> 1; i.e. 9 steps for 512 files, BUT doing them one by one... on average you'd need to swap ~256 files to find the problem one - at worst 512 and at best 1. BUT I think 9 steps v. ~256 is the better bet πŸ˜„
