    How to reduce file weight
    3 Posts 3 Posters 729 Views 3 Watching
      marufarch
      when i import cadfile(purged and with few layers)in sketchup ...sometimes it become heavy ..to move or to work with tht....is there amyu other way or plugins to reduce the sketchup file weight
        Hi Maruf (and welcome).
        It really depends on the file. If it is a floor plan, what would you leave out?
        If it is a set of terrain contour lines, you may try Simplify Contours from the bottom of this page:
        http://sketchup.google.com/intl/en/download/rubyscripts.html
          Maruf
          You say 'weight' - but is it the actual 'size' of the resultant SKP file or the 'heaviness' == 'slowness' in editing or navigating around the SKP etc after the import ?
          Have you also kept the CAD files 'origin' [see import > options], if so then that can slow the SKP; also sometimes CAD 'Blocks' become SKP 'Components' with strangely placed origins, you can change the component's axes to somewhere more sensible by using the right-click context-menu...
          Have you used the SKP's Model Info > Statistics > Purge Unused after the CAD import as there can also be a lot of unneeded stuff brought in even after you've purged the CAD version first. Also run 'audit' on the CAD file after a 'purge' just to ensure there's nothing wrong with the CAD data before the import...
