    Segmenting a cube or rectangle
    7 Posts 5 Posters 871 Views 5 Watching
    • D
      Don Pepz
      Hello guys,
      I wonder if there is a plugin to divide let say a cube in equal segments over de x,y and z axis. I searched over the forums but could not find anything, so I hope someone can help.
      Thanks in advance.
      • TIGT
        Try thomthom's EdgeTools that divide faces...
        • D
          Don Pepz
          Hi TIG,
          I tried edgetools but I would have to place the segments one by one (I don't know if I am right here). I thaught that there will be something faster like how silo or modo works by just filling in how much segments you want in the x,y and z axis and then every edges pops up nicely even over the mesh/cube.
          • BoxB
            There is Voxelize, don't know if it does what you want though.
            http://forums.sketchucation.com/viewtopic.php?f=180&t=36063#p317499
            • D
              Don Pepz
              Hi Box,
              hmmz did not know about this plugin. Can be handy someday ๐Ÿ‘ when I need it, but it is not what I was looking for. The voxelize plugin makes cubes groups out of the mesh but I only need the edges. Let say I want 3 segments in z-axis or all other axis.
              • sdmitchS
                sdmitch
                Don,
                Check out my model using the link below.
                http://sketchup.google.com/3dwarehouse/details?mid=c94cc88f44b94e401f3d773b4af1f0c9
                I created it by creating the the two 'solids', selecting the front and right side faces before executing a plugin of mine. Is this what you were looking for?
                http://sdmitch.blogspot.com/
                • srxS
                  srx
                  I would subdivide it with Subdivide and smooth and then erase diagonals ๐Ÿ˜„
                  www.saurus.rs
