    [Plugin] Voxelize - Updated 2011-04-04
    48 Posts 21 Posters 62.0k Views 21 Watching
      Try Qubicle πŸ˜„
      • OxerO Offline
        Oxer
        Thanks for the plugin, I have made an icon for the plugin but I don't know ruby code to create the toolbar for the plugin, if you are insterested here the icons.
        Voxelize Icons.zip
        [http://www.oxervision.blogspot.com/(http://www.oxervision.blogspot.com/)]
        • I Offline
          iasef25
          How can I count the the boxes (cubes) after voxelization? Is there any automatic method to count it?
          Thank you.
          Iasef.
            @iasef25 said:
            Thank you.
            Iasef.
            The answer to your question is just a few posts above yours. It's amazing what you'll see if you spend a few seconds looking. πŸ˜‰
            Since the plugin creates the cubes as instances of a component, select one of them and look at the Entity Info box. It'll tell you how many there are.
            • BoxB Offline
              You can say that again.
              • I Offline
                iasef25
                Hi Dave R,
                Thank you so much !
                πŸ˜„
                Iasef.
                  Qubicle 2 soon! πŸ˜„
                  • fionmacoolF Offline
                    fionmacool
                    Cool plugin. Cheers.
                    Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
                    • 3 / 3
