    [Plugin] Voxelize - Updated 2011-04-04
    48 Posts 21 Posters 64.6k Views 21 Watching
    • O Offline
      octopus2
      Is there a way of knowing how many cubes were generated?
        Since the plugin creates the cubes as instances of a component, select one of them and look at the Entity Info box. It'll tell you how many there are.
          TheDro
          If you open up Window>>Ruby Console, before running the plugin, the debug information will tell you how many cubes were created, among other things. The other things are the amount of time each step takes to run. This is probably more helpful to me than to you but remember, this is still in beta πŸ˜„.
          • F Offline
            Flashhawk
            You are kidding me right? I mean you must kid me!! I did this by hand last week!!! I was totally not aware of your script and i made a voxelized soldier for a 3d Print project (3mm or 1/600 scale infantry) by overlaying a 3d-warehouse model with a matrix of 30x30x30 voxel and then deleting everything that was not used... (like in Michelangelos "I chipped off everything that did not look like a lion") Man i will so much use this next time!!!! Thanks alot!
            Flashhawk
            • Dan RathbunD Offline
              Dan Rathbun
              @thedro said:
              I just checked out some of the methods of components (instance and definition) and there is a " bounds" method (not found in the api documentation...)
              Yes it is.
              bounds() is defined in class Drawingelement
              Group, ComponentDefinition, ComponentInstance are all subclasses of Drawingelement, so they inherit their superclass' instance methods.
              At the console:
              Sketchup::Group.superclass()
              Sketchup::Drawingelement
              Sketchup::Drawingelement.superclass()
              Sketchup::Entity
              .. so they also have all Sketchup::Entity instance methods. And Sketchup::Entity is a subclass of Object so they have all of those instance methods, and module Kernel is mixed into Object, so they will have of those methods.
              I'm not here much anymore.
                Anton_S
                πŸ˜† Does anyone play Minecraft? -- everything is made of cubes
                  Try Qubicle πŸ˜„
                  • OxerO Offline
                    Oxer
                    Thanks for the plugin, I have made an icon for the plugin but I don't know ruby code to create the toolbar for the plugin, if you are insterested here the icons.
                    Voxelize Icons.zip
                    • I Offline
                      iasef25
                      How can I count the the boxes (cubes) after voxelization? Is there any automatic method to count it?
                      Thank you.
                      Iasef.
                        @iasef25 said:
                        Thank you.
                        Iasef.
                        The answer to your question is just a few posts above yours. It's amazing what you'll see if you spend a few seconds looking. πŸ˜‰
                        • BoxB Offline
                          You can say that again.
                          • I Offline
                            iasef25
                            Hi Dave R,
                            Thank you so much !
                            πŸ˜„
                            Iasef.
                              Qubicle 2 soon! πŸ˜„
                              • fionmacoolF Offline
                                fionmacool
                                Cool plugin. Cheers.
                                Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
                                • 3 / 3
